An external optical drive by Apple, essentially a rebranding of the MacBook Air SuperDrive.
How do I open the casing?
I have this external disc drive. There is a CD or DVD in it that wont eject. I hear it trying to catch the cd/dvd, yet I don't hear the spinning sound. Is there any way I can open the casing? I don't see any screws on t at all...
Score 3
Add a comment
Chosen Solution
Steven, take a look at this guide.
Score 2
Add a comment
use a big suction cup to lift the bottom plate up so you will not damage the casing. this is what the official apple service manual says
Score 2
Add a comment
Without the suction cup, there are three simple snap tabs on either side of the case which can be pushed back with playing cards to open the case. You then need a Torx 10 and Phillips #00 or #000 drivers to remove three screws which hold down the drive in the case. After pivoting the drive up, you need to remove the two side Torx screws that fasten a mounting plate and 4 small Phillips screws to lift up the top plate and remove the stuck disk.
I was going to grant access to the paperclip eject hole I expected to find, but THERE IS NONE! If software won’t eject a disk in this drive, there is no option but DISASSEMBLY!
Jim
Score 1
1 Comment:
Thank you very much
by
Add a comment
Add your answer
steven will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 115
All Time: 13,161
