Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
iRobot Roomba i7 Does Not Charge
The iRobot Roomba i7 does not charge when connected to the Home Base.
Home Base is Not Connected
Check that your home base is plugged into an outlet.
Unit Needs to be Rebooted
When the Roomba i7 battery is not charging, it might be helpful to reboot the device. To do this, hold the CLEAN button for 20 seconds until the light ring around the CLEAN logo starts spinning around. The device will then take up to 2 minutes to turn on again. When the light turns off, the reboot is complete.
Battery is Not Installed
Check the battery compartment to ensure that the battery is installed. If it is not installed, follow the procedure to install it.
Battery Needs Replacement
Your battery may need to be replaced. Please see this guide for replacing iRobot Roomba i7 Battery.
Front Bumper Loses Connection
The iRobot Roomba i7 is not moving and continuously giving an error.
Error 9: The Bumper is Stuck and Not Moving Freely
Try tapping the bumper several times. This may dislodge any debris that may have been trapped underneath. Then press CLEAN to restart the device. If no debris is found using this method, then use this guide.
Error 16: The Bumper is Either Dislodged or the Device is Tilted
If the iRobot Roomba i7 is unable to start cleaning due to a possible tilt, move the Roomba to a FLAT surface then press CLEAN to restart. Do not move the Roomba while pressing the CLEAN button. If the “Error 16” still occurs, reboot the Roomba. To do this, hold the CLEAN button for 20 seconds until the light ring around the Clean logo starts spinning around. The device will then take up to 2 minutes to reboot. When the light turns off, the reboot is complete.
Bumper Needs Tightening
If the Roomba is still not cleaning and displaying “Error 16,” then use this guide to tighten the dislodged bumper.
Wheels Won’t Turn
The main wheels on the iRobot Roomba i7 fail to turn or are blocked by debris.
Error 5 the Left or Right Wheel Will Not Turn Due to Debris
If one of the Roomba’s wheels is not turning and giving an “Error 5” message, flip over the device and push the “problem” wheel in and out multiple times. Check the wheel well for debris and try to shake it out. If the debris fails to dislodge, use this guide to remove wheels and then remove the debris. After clearing the debris reinstall the wheels and manually rotate them several times ensuring similar resistance between the wheels. Then, press CLEAN to restart the device.
Broken Wheel
If the Roomba’s wheel fails to turn, use this guide to remove and replace the broken wheel(s).
Side Brush Won’t Spin
The spinning side brush on the iRobot Roomba i7 fails to turn or is broken completely.
The Roomba Side Brush is Not Spinning Due to Jam
If the side brush is not spinning, there could be a jam inside the mechanism. To fix this problem, remove the side brush using this guide and manually clean around the brush.
The Roomba Side Brush is Broken
If the side brush is broken, remove the broken brush and replace it with a new brush using this guide.
iRobot Roomba i7 Won’t Clean
As the iRobot Roomba i7 travels around the room, it doesn’t seem to pick up dirt.
Faulty Cleaning Head System
Can you hear the vacuum sucking air into the Roomba? If it isn't making a sucking sound, the vacuum is broken. Consider buying a replacement cleaning head system.
Clogged Filter
Remove filter from the device. If there are large amounts of dirt and debris, the filter may be clogged. Consider replacing or cleaning the filter by following this guide.
53 Comments
Our vacuum won’t leave the charger. Keeps saying empty the bin, which we have done. We were very happy with the first two roomba’s , is this something specific to the i7”s?
char.barnett306 - Reply Share
I have the same problem, replaced both the bin and cleaning module and still seeing the same error. Does anyone have any ideas?
Paul Y - Reply Share
Same here, it's fully charged, filter changed, it will empty but, it will not leave the charging station.
Julie G - Reply Share
I cant get the brushes out altho I followed the Tutorial.
sylsew - Reply Share
I got this in September and it is now October and I see it as a lemon . I have an older irobot from 2016 and it runs better than this one. To spend over 1k on a vacuum and have to contact customer support multiple times is a bit much. This didnt help me solve my latest problem of it not turning on for more than 10 seconds without giving me the put on a flat surface error.
Alexandria - Reply Share
Past 24 Hours: 3
Past 7 Days: 39
Past 30 Days: 175
All Time: 66,013
