iRobot Roomba i7 Battery Replacement
    1. iRobot Roomba i7 Battery Replacement, Battery: step 1, image 1 of 3 iRobot Roomba i7 Battery Replacement, Battery: step 1, image 2 of 3 iRobot Roomba i7 Battery Replacement, Battery: step 1, image 3 of 3
      • Warning: Swollen or cracked batteries can be hazardous to humans due to fumes or potential fire. If you feel unsafe at anytime completing this guide, put your device in a fireproof container and take it to a replacement professional.
      • Flip the iRobot Roomba i7 so that the underside is facing upwards.
      • Using a Phillips #1 screwdriver, loosen the following screws:
      • 6.27mm-screw in the center of the side brush.
      • Five 6.24mm-screws on the bottom cover.
      Ask FixBot
    2. iRobot Roomba i7 Battery Replacement: step 2, image 1 of 1
      • Carefully remove the bottom cover.
      • If the cover is stuck or hard to remove, use a prying tool to separate it from the device.
      Ask FixBot
    3. iRobot Roomba i7 Battery Replacement: step 3, image 1 of 2 iRobot Roomba i7 Battery Replacement: step 3, image 2 of 2
      • Before removing the battery, make sure that it is not hot or swollen. Swollen lithium-ion batteries release gases that are hazardous for humans.
      • Unclip the original battery and pull upwards to remove it.
      • Use a prying tool if necessary.
      Ask FixBot
      • Close the Roomba app on your mobile.
      • Remove the battery from your Roomba.
      • Hold the start button for 10 seconds.
      • Reinstall the battery and charge for a full cycle. Wait for your Roomba to automatically start itself.
      • Open the mobile app and reconnect to your Roomba.
      Ask FixBot
Battery Disposal: Never dispose of old batteries in the trash. For proper disposal, take it to your local battery recycling facility. You can find one by doing a quick internet search for "battery recycling facility" and including your zip/postal code or city name in the search. Also, check out http://call2recycle.org and plug in your zip/postal code. This will show you all of the registered drop-off locations near you.
5 other people completed this guide.
5 Guide Comments
Its a shame the battery is so small compared to the cavity. The run time could be greatly expanded by simply putting in a larger battery.
Reid Kersey - Reply Share
iFixit sells a larger battery that fills the cavity. My i7 used to take 2 charge cycles to clean the main floor of the house. Now it can do it in a single charge. iRobot Roomba i7 Battery Replacement
Justin Vanderhooft - Reply Share
I bought this battery a bit ago and it would never charge :(
Gary Hulse - Reply Share
My j7+ says it cannot detect the battery. I have had alot of battery issues where the robot just dies where its at or doesnt charge at the base unless rebooted. Any ideas?
Rick Moore - Reply Share
What is charging error 19
Past 24 Hours: 20
Past 7 Days: 139
Past 30 Days: 451
All Time: 39,736
