Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Leaving Clumps of Dirt on the Ground
After the Roomba vacuums, dirt and filth is still left behind.
Hair in Main Brush Head
Check the main brush heads as hair can often get tangled in them and clog them. To get better access to the main brush head follow the first 6 steps of this guide and remove the hair.
Clogged filter
The filter needs to be replaced approximately once every month or sooner depending on frequency of use. Follow the steps in this video to replace the filter.
Replacement part: HEPA Filter
Damaged Brushes
The main brush heads can get damaged from regular use or improper installation. Follow the steps outlined in the Cleaning Head Replacement guide for how to replace damaged brushes.
Rubber Brushes Jammed
The main brushes at the bottom of the Roomba do not rotate when the Roomba is cleaning.
Hair Buildup
Hair often gets tangled in the brushes and causes them to seize. By simply removing the brushes and cleaning out the hair, you can usually get it working again. To remove the brushes, follow this guide. Make sure to remove the end cap and remove the hair from each brush before reinstalling.
Brushes Damaged
The brushes could have sustained damage from long term wear. You can purchase a new set of brushes and install them.
Battery Won’t Charge
The Roomba will not charge when connected to the home base.
The Home Base Isn’t Properly Set Up
Make sure that the Home Base is plugged into an outlet and is on the floor in an area the Roomba can properly reach.
The Roomba Isn’t Connected to the Home Base
Check that the Roomba’s charging contacts are placed properly on the Home Base’s charging contacts. There should be a green light on the Home Base if the Roomba is properly connected. The Roomba should rest flat if placed correctly on the Home Base.
The Battery is Dead
The battery in the Roomba may have been faulty or died from use. You’re going to want to replace it.
Parts: Battery
Roomba Can’t Reach its Home Base
The Roomba can only recharge when it docks on the Home Base. If the Home Base is on a different level of the house, or separated by stairs or other obstacles, the Roomba won’t be able to return to charge. If there is something blocking the Home Base charging contacts, or the Home Base isn’t turned, on the Roomba won’t be able to charge at it either.
Malfunctioning Battery
If the battery is losing charge unusually quickly after leaving the Home Base, or the battery doesn’t charge at all, then the battery has probably reached the end of its life.
Replacement part :Roomba Battery 3000mAh
Can’t find Home Base: IR Sensor malfunction
The Roomba uses a r-con sensor to communicate with the Home Base. If the sensor is damaged it won’t be able to find the Home Base and can’t charge itself. Follow our guide on how to replace the IR sensor.
Roomba Drives in circles
The Roomba drives in circles as if a wall is in front of it.
Bumper Spring Malfunction
Check to see if the bumper on the front of the robot is stuck and will no longer depress. Briskly tapping the bumper repeatedly should dislodge any debris jamming it up.
Bumper Sensor/Cliff Sensor Malfunction
Check the condition of the Bumper Sensor and Cliff sensors located on the bottom of the robot. If they are covered in dirt, clean them off. After this process if the robot continues to drive in circles they may need to be replaced; luckily, we have a handy guide to show you how!
Malfunctioning Drive Wheel Module
If the Roomba only appears to drive on one side, if it favors a counterclockwise or clockwise location, one of the drive wheel modules may be broken. Follow our guide on how to replace the Wheel Module here.
Dustin Staples
339 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 37
All Time: 1,521
