Up to 20% off select tools
iRobot Roomba 890 Motorized Wheel Module Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
76
All Time:
1,382
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The iRobot Roomba 890, Model #R890020, is an autonomous robotic vacuum cleaner that is intended to make cleaning more accessible and convenient. If your Roomba 890 wheels become blocked with hair or dust, it is a good idea to replace them. This guide will teach you how to remove and replace the Roomba's two motorized wheel modules, which will help prevent floor damage. There are no specific needs or prerequisites for understanding and implementing the procedures outlined in this guide.
    1. iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: step 1, image 1 of 2 iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: step 1, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the 7.7 mm screw securing the side brush-head.
      • Remove the yellow brush head.
      Ask FixBot
    2. iRobot Roomba 890 Motorized Wheel Module Replacement: step 2, image 1 of 1
      • Place the Roomba with its bottom facing toward you.
      • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
      Ask FixBot
    3. iRobot Roomba 890 Motorized Wheel Module Replacement: step 3, image 1 of 2 iRobot Roomba 890 Motorized Wheel Module Replacement: step 3, image 2 of 2
      • Remove the battery by pulling directly up on the grey pull tabs.
      Ask FixBot
    4. iRobot Roomba 890 Motorized Wheel Module Replacement: step 4, image 1 of 1
      • Lift off the baseplate.
      Ask FixBot
    5. iRobot Roomba 890 Motorized Wheel Module Replacement: step 5, image 1 of 2 iRobot Roomba 890 Motorized Wheel Module Replacement: step 5, image 2 of 2
      • Remove the collection bin by pressing the release button on the top side of the Roomba and pulling straight out.
      Ask FixBot
    6. iRobot Roomba 890 Motorized Wheel Module Replacement: step 6, image 1 of 2 iRobot Roomba 890 Motorized Wheel Module Replacement: step 6, image 2 of 2
      • On the underside of the Roomba, use a Phillips #1 screwdriver to remove the three 15.5 mm screws.
      Ask FixBot
    7. iRobot Roomba 890 Motorized Wheel Module Replacement: step 7, image 1 of 1
      • Grip both sides of the casing and pull it straight out.
      Ask FixBot
Author
with
Dustin Staples
339 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 76
All Time: 1,382
