The Roomba 4100 is an autonomous vacuum cleaner manufactured by iRobot.
The Roomba won't turn on
There is a problem with your power supply or battery.
The battery is dead and needs to be replaced
If the Roomba won't turn on, it may have a dead battery. Depending on how frequently you use your Roomba, the battery pack will need to be replaced every 1 to 3 years. If you have tried charging your Roomba overnight and it still won't turn on, the only repair option is to order another battery from a Roomba vendor and recycle the bad battery. Refer to Battery Replacement Guide
The Roomba is not cleaning effectively
The Roomba is not picking up dirt, hair, or other debris.
The filter is clogged and may need to be replaced
If your Roomba is leaving debris or dirt that should've been picked up, the filter may be clogged. The filter needs to be cleaned regularly or replaced after excessive use. Refer to Filter Replacement Guide
The main brush is not cleaning or rotating and may need to be replaced
If the main brush is not cleaning or rotating, it may need maintenance. The main brush may need to be cleaned if it is clogged with debris. It may need to be replaced if it is worn down from excessive use. Refer to Main Brush Replacement Guide
The flexible rubber brush is not cleaning or rotating and may need to be replaced
If the flexible rubber brush is not cleaning or rotating, it may need maintenance. The flexible rubber brush may need to be cleaned if it is clogged with debris. It may need to be replaced if it is worn down from excessive use. Refer to Flexible Rubber Brush Replacement Guide
The edge brush is not rotating
The small blue brush that sticks out from underneath the Roomba is visibly broken or fails to rotate.
The edge brush is broken and needs to be replaced
If the edge brush is not rotating or is damaged, it may be broken beyond repair. The edge brush is delicate and may need to be replaced after excessive use. Refer to Edge Brush Replacement Guide
The brushes are falling out of place
The main brush and the flexible rubber brush might fall out of place if the brush guard constraining them is broken.
The brush guard is broken and needs to be replaced
If the main brush or flexible rubber brush fall out of place, your brush guard may be broken. If it is broken beyond repair, a new brush guard may be purchased from a Roomba vendor. For brush guard replacement refer to Brush Guard Replacement Guide
Scott Leonard
445 Reputation
3 Guides authored
Cal Poly, Team 20-6, Maness Fall 2010 Member of Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Members
36 Guides authored
9 Comments
See more information here:
iRobot Roomba 4100
Scott Leonard - Reply Share
my 4100 has been in storage for a couple of years. I have everything plugged in right. I get no power indication on the 4100 or on the charger pack that plugs into the dock. Any ideas?
Davemaque@comcast.net
davemaque - Reply Share
the front wheel on my iRobot 4100 is not moving up and down
DK SHOCK - Reply Share
My Roomba is going around in circles
kellycirco2 - Reply Share
I need a new charging cord . WHere can I get one?
Ruth Johnson - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 46
All Time: 11,361
