iRobot Roomba 4100 Brush Guard Replacement
    1. iRobot Roomba 4100 Brush Guard Replacement, Brush Guard: step 1, image 1 of 1
      • Lay the Roomba upside down on a flat surface with the blue strip away from you.
      Ask FixBot
    2. iRobot Roomba 4100 Brush Guard Replacement: step 2, image 1 of 2 iRobot Roomba 4100 Brush Guard Replacement: step 2, image 2 of 2
      • Use your index fingers to pull the yellow tabs towards you.
      • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
      • For reassembly, make sure to push in the brush guard until it clicks into place.
      Ask FixBot
    3. iRobot Roomba 4100 Brush Guard Replacement: step 3, image 1 of 1
      • Pull back the brush guard to unhook it from the latches.
      • Remove the brush guard by lifting it up and out of the Roomba.
      • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
      Ask FixBot
Samantha Barrett
501 Reputation
5 Guides authored
Cal Poly, Team 17-5, Forte Winter 2014 Member of Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 57
All Time: 1,181
