iPod Mini 1st Generation Troubleshooting
The 1st Generation Mini looks like the 2nd Generation Mini, but it does not have the capacity printed on the back.
iPod won't turn on
No matter what you do, you can't get your iPod to turn on.
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input on the click wheel and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, it must be replaced with a new battery.
Bad logic board
If your iPod does nothing when plugged into a computer, the problem most likely lies in the logic board. We offer logic boards, as well as the instructions for installing them.
Bad display
It is possible that it appears nothing is happening because the display is bad. If you hold the iPod up to your ear you should be able to hear the hard drive spinning. If the iPod sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced.
Bad click wheel
If absolutely nothing happens, it is possible that your iPod is not receiving your instructions because the click wheel is bad and must be replaced.
No audio or distorted audio
Your iPod turns on and appears to work, but when you plug in headphones or speakers, the audio doesn't play properly.
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPod with another set of headphones or speakers just to make sure that the problem is with the iPod.
Bad audio jack
The most likely cause of audio output problems on iPods is a bad audio-out jack board. We offer the Mini headphone jack boards, and we offer free guides for replacement.
Sad iPod icon on startup
The iPod displays an image of a sad iPod when turned on
Corrupted software
Sometimes, a reset and restore will fix a sad iPod. Connect your iPod to your computer and use iTunes to restore the iPod. Restoring the iPod will erase everything on it, so make sure everything on the iPod is stored elsewhere prior to restoring. Sometimes it may be necessary to restore the iPod several times before it works properly. If you are unable to restore your iPod using iTunes, you can hard reset your iPod. IPod Minis can be hard reset by booting while holding the menu and play/pause buttons. This should result in a quick dark screen followed by the standard Apple boot graphic.
Bad logic board
If restoring the iPod didn't work, the sad iPod is likely caused by a problem with the logic board. There's not much to troubleshoot here. Basically, the only option is to replace the logic board.
Folder icon appears on startup
The iPod displays an image of a folder when turned on.
Bad hard drive or cable
One of the best methods to diagnose a failing hard drive is to listen to the drive. If you put your iPod up to your ear, you should hear a smooth-sounding whirr of the hard drive spinning. Any loud clicking or grinding sounds may mean that your iPod's drive is failing. If you don't hear anything, the drive is not getting power or is very damaged and can't spin up. In this instance, replacing the hard drive cable first is a good idea. Then, if the problem persists, replace the hard drive.
The iPod either boots to an Apple logo and freezes or continuously reboots.
Bad logic board
This is likely the cause, and the logic board must be replaced.
Author
with
Luke Soules
107,867 Reputation
21 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
4 Comments
Hello friend, I'm a very serious problem.
I went to upgrade the IPOD mini and pro inattention not aterei the key hold, it damaged the IPOD, I believe that any regulator, and this happened to two devices, do not want to lose these devices, I know it can be something simple, but I do not have the knowledge to locate the fault, but I know that surely someone must have already had the same problem. I found on the Internet a solution, so I write kindly to know if you have a solution.
The unit turns, not boot disk when plugged into the USB recognizes the disc and restart.
Very grateful if you can help me.
wertoliveira - Reply Share
I got this iPod mini thing a little bit of time ago. Not from online for some reason the battery won't charge and when it does it won't last more that about 10 seconds. I would like to know where I can get a new battery and get it repaired and how much that would cost. I know it is old technology but I actually like it. I would be very grateful if I got some help. Thanks
Ella Roady - Reply Share
Hi , how do I put my iPod mini a1051 back into English as I have inadvertently put it into Japanese while 're setting it ????
Regards Nick in York
Nick Duck - Reply Share
Hello! For whom it may concern - I got 1st gen ipod mini, which after multiple format attempts did not restore successfully in iTunes - it failed with the generic error. I tried everything and multiple windows computers. It turned out, the cable, even though new, was at fault. Changed to the old one and restore was successful.
Kristaps Liepnieks - Reply Share
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 173
All Time: 52,876
