Up to 20% off select tools
iPod Mini Display Replacement
Views: 44K
View statistics:
Past 24 Hours:
10
Past 7 Days:
48
Past 30 Days:
300
All Time:
43,915
Comments: 25
23 comments on steps, 2 guide comments.
Go to guide comments
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Replace a cracked or faulty display.
    1. iPod Mini Display Replacement, Top Bezel: step 1, image 1 of 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Ask FixBot
    2. iPod Mini Display Replacement: step 2, image 1 of 1
      Tool used on this step:
      Jimmy
      $7.95
      Buy
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
      • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
      • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
      Ask FixBot
    3. iPod Mini Display Replacement: step 3, image 1 of 1
      • Lift the top bezel off of the iPod.
      Ask FixBot
    1. iPod Mini Display Replacement, Bottom Bezel: step 4, image 1 of 1
      Jimmy
      $7.95
      Buy
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
      Ask FixBot
    2. iPod Mini Display Replacement: step 5, image 1 of 1
      • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
      • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
      Ask FixBot
    3. iPod Mini Display Replacement: step 6, image 1 of 1
      • Lift the metal retaining bracket out of the iPod.
      Ask FixBot
    1. iPod Mini Display Replacement, Display: step 7, image 1 of 1
      • Be careful, this connector is fragile.
      • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
      Ask FixBot
    2. iPod Mini Display Replacement: step 8, image 1 of 1
      • Remove the two #00 Phillips screws securing the headphone jack to the casing.
      Ask FixBot
    3. iPod Mini Display Replacement: step 9, image 1 of 1
      • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
      • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
      Ask FixBot
    4. iPod Mini Display Replacement: step 10, image 1 of 1
      • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
      Ask FixBot
    5. iPod Mini Display Replacement: step 11, image 1 of 1
      • Lift the battery off of the logic board and lay it to the side of the iPod.
      Ask FixBot
    6. iPod Mini Display Replacement: step 12, image 1 of 1
      • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
      • This tab is fragile so be careful not to break it.
      Ask FixBot
    7. iPod Mini Display Replacement: step 13, image 1 of 1
      • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
      Ask FixBot
    8. iPod Mini Display Replacement: step 14, image 1 of 1
      • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
      Ask FixBot
    9. iPod Mini Display Replacement: step 15, image 1 of 1
      • Turn the iPod over.
      • Carefully lift the display up and slide it out of its connector.
      Ask FixBot
27 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
2 Guide Comments
Hey when I tried to lift up the tab ,it came out flying what to do now ?
Vatsal - Reply Share
I can't get the logic board to slide out. What should I use? Do you think heat would help
Ohdoh - Reply Share
Past 24 Hours: 10
Past 7 Days: 48
Past 30 Days: 300
All Time: 43,915
