iHome won't turn on
When you put the batteries in, the iHome won't turn on.
iHome won't get power when plugged in
Your power adapter may be bad. It can be replaced.
iHome won't get power when going on battery
The device may also be powered by 4 AA batteries. Replace them at bottom of the case.
iPod adapter won't charge iPod
Your iPod connects and plays correctly, but won't charge.
Device is unplugged
Check to make sure device is plugged into wall.
Device has no batteries
Replacing batteries may help the iPod charge. There are 4 AA batteries at the bottom of the case.
Power to the adapter may have been severed
You can check if the power is going to the adapter correctly.
iPod Adapter is broken or iPod won't connect
You can't get your iPod onto the device because the adapter is broken or warped.
Warped Shape / Cracked Adapter
Connecting a new adapter is very quick and easy.
Clock loses track of time when replacing batteries
Watch Battery May Be Broken
Your watch battery is probably dead. Replace it as you would any other AA battery, at the bottom of the case.
Speaker isn't emitting sound or the sound is muffled
Check the connection with the circuit board
It is possible that only the connection to the speakers is broken.
Broken Speakers
Unfortunately, the speakers can not be opened. However, they are easily replaced.
*iHome iH27B AV circuit board Replacement
A button is unresponsive or broken
You click a button and it doesn't do anything.
Left Control Button is broken
*iHome iH27B Left Control Button Replacement
Right Control Button is broken
*iHome iH27B Right Control Button Replacement
Daylight Savings Time Switch is broken
*iHome iH27B Daylight Savings Switch Replacement
Display is not working or has artifacts
The display behind the clear plastic never turns on or has strange marks.
Display can not be replaced
The display is attached in such a way as to make replacement very difficult
iHome will not work with my 3G iPod
This unit will not control or charge a third generation iPod.
Jordan Petersen
49 Reputation
0 Guides authored
Cal Poly, Team 3-21, Amido Fall 2012 Member of Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Members
108 Guides authored
1 Comment
can i locate my speaker i lost it please help me
theglassheartcastle - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 15,948
