Up to 20% off select tools
iHome iH27B Left Control Button Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
81
All Time:
1,509
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. iHome iH27B Left Control Button Replacement, Outer Case: step 1, image 1 of 1
      • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
      • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
      Ask FixBot
    2. iHome iH27B Left Control Button Replacement: step 2, image 1 of 3 iHome iH27B Left Control Button Replacement: step 2, image 2 of 3 iHome iH27B Left Control Button Replacement: step 2, image 3 of 3
      • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
      • Remove the plastic slide from its location and set it aside.
      • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
      • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
      • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
      • Set the plastic covering and the watch battery aside.
      Ask FixBot
    3. iHome iH27B Left Control Button Replacement: step 3, image 1 of 1
      • Remove the following screws:
      • Eight 10 mm using the Phillips #0 on the bottom of your device.
      • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
      Ask FixBot
    4. iHome iH27B Left Control Button Replacement: step 4, image 1 of 1
      • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
      • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
      Ask FixBot
    5. iHome iH27B Left Control Button Replacement: step 5, image 1 of 1
      • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
      • You should have visible access to most of the components inside the iHome now.
      Ask FixBot
    1. iHome iH27B Left Control Button Replacement, AV circuit board: step 6, image 1 of 1
      • Two 10 mm Phillips #0
      Ask FixBot
    2. iHome iH27B Left Control Button Replacement: step 7, image 1 of 1
      • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
      Ask FixBot
    1. iHome iH27B Left Control Button Replacement, Main Motherboard: step 8, image 1 of 1
      • Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
      Ask FixBot
    2. iHome iH27B Left Control Button Replacement: step 9, image 1 of 1
      • Remove the following 6 screws:
      • Two 7 mm Phillips #0
      • Three 10 mm Phillips #2
      • One 9 mm Phillips #2
      • Set the screws aside, careful to not mix them up with your other screws.
      Ask FixBot
    1. iHome iH27B Left Control Button Replacement, Left Control Button: step 10, image 1 of 2 iHome iH27B Left Control Button Replacement, Left Control Button: step 10, image 2 of 2
      • Remember that the device is still upside down, so the left control button will be on your right hand side. Then rotate the device 180 degrees. You should see the device as it looks in the picture.
      • Carefully lift the iHome about an inch from your surface to verify you are going to the correct spot, because the iHome looks symmetrical at this point.
      • Carefully lift the main motherboard out of the way of the button control circuit board.
      • Four 6 mm Phillips #2
      Ask FixBot
    2. iHome iH27B Left Control Button Replacement: step 11, image 1 of 2 iHome iH27B Left Control Button Replacement: step 11, image 2 of 2
      • Carefully lift the button control motherboard out of the way.
      • Place your fingers on each of the four notches. Apply pressure towards the center, and push downwards until the plastic piece is dislodged from its casing.
      • If your fingers aren't working, use a flathead screwdriver or plastic prying tool to give you extra leverage.
      Ask FixBot
    3. iHome iH27B Left Control Button Replacement: step 12, image 1 of 1
      • Replace your cracked or otherwise broken button with the new button.
      Ask FixBot
Author
with
John Kraemer
76 Reputation
9 Guides authored
Cal Poly, Team 3-21, Amido Fall 2012 Member of Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 81
All Time: 1,509
