Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Unit Won’t Turn On
  • Screen does not display info or light bar and buttons do not light up.
Faulty outlet
  • Test the unit at a different outlet.
AC Adapter is not connected to the outlet or unit properly
  • Make sure that if the outlet is tied to a switch, make sure they are flipped into the on position.
  • Verify that the connection between the AC cable and the DC jack is secure.
Warning:
  • If the included AC adapter is used on other devices other than the iHome, this poses a potential risk to damage to damage them as well as the adapter.
Device Does Not Respond
  • Unit does not respond to the connected device.
Not Properly Connected to Power Source
  • Check that the unit is on.
    • The display and buttons on top of the unit light up.
  • Adjust the volume on device and unit.
  • Test the play and pause buttons on your device and unit.
  • Reset the Bluetooth on your device.
    • Turn the Bluetooth off, wait a few seconds, then turn it back on
  • Check that the device is properly paired to the unit.
    • Verify that the iHome iAVS16 appears in your device’s Bluetooth menu.
No Sound
  • The connected device shows that the unit is playing audio but no sound comes out of the unit.
Volume is too low
  • Turn the volume up on unit and/or on your device.
Distorted Sound
  • Sound is unclear/hard to understand.
Volume is too high
  • Lower the volume on your device or unit.
Sound source is distorted
  • Upgrade quality of audio files.
    • If using a service like sound cloud try playing the file from a different source
  • Refer to erratic performance troubleshooting section.
Inaccurate Clock Display
  • Time on unit does not match time on app.
Time zone set incorrectly in app
  • Make sure time zone is set correctly in the Alexa app.
    • In the Alexa app> Devices> the iHome> Device location or Device time zone
  • Make sure time zone is set correctly in the iHome AVS16 app.
    • In the AVS app> settings (bottom right)> Time zone
Erratic performance
  • Unit sound cuts out.
External interference
  • Move unit away from potential sources of interference
    • such as computers, modems, other wireless devices, or fluorescent light.
  • Move your device closer to the unit.
    • Bluetooth has a limited range, moving your device closer to the unit may clear up playback issues
Trouble Connecting Via Bluetooth
  • Unit has trouble connecting to the device.
  • Unit disconnects from device.
Device is too far away from unit
  • Move the device connected to the unit closer.
Marco Sousa
293 Reputation
2 Guides authored
16 Comments
How do I fix “update failed"?
Deborah (Debbie) Spataro - Reply Share
After my unit warms up the speaker has a popping sound like every second. Some times is stops for a moment. But usually it pops. It is like a faulty connection speaker pop.
Bob Reece - Reply Share
Mine is doing the exact same thing. Not found any help. Ihome tech said it had a bad component and would be cheaper to buy a new one the repair. I can't believe it should die in 3 years.
Jpd - Reply Share
how come the base lights are stuck on lime green can not change even reset unit still stuck on lime green
dwight horton - Reply Share
Base lights just came on and will not stop. I went in to turn “off” the lights but they are still on and changing color. What happened to make them come on and stay on?
Shawn Farney - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,742
