Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen has a distorted display or is broken
The screen's display has dead pixels, is glitching, or is visibly broken.
Software error
If the screen flickers or flashes when transitioning between apps, it may be a software issue that can be resolved with an update. Make sure your device has an internet connection, and your battery is at more than 50% charge or charging while installing. Open Settings >> About the phone >> Software Update >> Update.
Screen is cracked/peeling
Due to physical damage or wear over time, the screen may deteriorate. In this case, you should replace the screen.
Phone will not power on even when plugged in.
Phone will not show anything or power on and instead restarts periodically even when it is plugged in with a swapped battery.
Buttons seem flimsy or loose
The motherboard detects button inputs and allows basic functions to occur, water damage or through time causes the buttons to malfunction or even the motherboard itself. The buttons will have to be replaced.
Faulty Charger
Even when plugged in the phone is still unresponsive and shows no signs of powering on. If the charger is working, the phone screen should turn on. If this does not occur, consider purchasing a replacement charger.
Loose Wires
When opening up the blackberry you could see unattached, exposed wires which may be the cause of no power. Try matching the wires using this guide.
Keyboard/keys will not respond
The phone is not responding to keys on the keyboard.
Phone has overheated
Due to the temperature of the operating system the keyboard may be unresponsive. Allow the device to idle at room temperature, if the device is cooled and still unresponsive, you should Replace your keyboard
Keys are sticky
There may be dirt or debris causing the keyboard to be faulty. Try cleaning the keyboard and see if the key begin to be responsive. If the keyboard is still unresponsive you should Replace your keyboard
Device is having connectivity issues
the phone will not respond despite pressing the power on button or phone is slow.
Phone battery is at 0%
This phone's battery has a lifespan of 2 days. After these two days you will need to recharge the phone by plugging it into a charging outlet. If the phone is unresponsive after sufficient charging, you may need to replace the phones battery.
Phone is slow
There may be connectivity issues to internet due to the phone's battery. Try restarting the phone. If this doesn't work, you should replace phones battery as it may be old.
Device is Overheating
The device is unresponsive to touch; display is black.
Battery is faulty
The device may be unresponsive due to overheating of the battery.Battery overheating may be caused by the use of device accessories. You should remove the phone case from your phone and allow it to cool. Battery replacement is necessary if the device continues to be unresponsive.
Overpowered Device charger
There may not be a problem with the device itself, but with the charging cord. Remove the charging cord and allow the device to cool. If the device becomes responsive, the charging cord may need to be replaced.
Damaged Motherboard
The display is distorted or doesn’t show anything. The root cause of this could be that the motherboard is damaged. Being the brain/heart of the system, it is crucial that the motherboard stays in pristine condition. This damaged motherboard will have to be replaced.
Distorted Display
It is possible that the damaged motherboard is correlated with the screen display. The screen will not turn on until the motherboard is replaced.
Fan not responsive
Without a functioning motherboard, the phone will not display anything on the screen. If the phone were to turn on it would overheat due to the fan not responding.
Carlos Acosta
51 Reputation
0 Guides authored
2 Comments
Hello sir
My blackbarry Display not working when changeing mobile only sensor led showing no on display what reason sir.
Ginson Mass - Reply Share
My blackberry Key2 while on wifi won't display the LTE light. Having trouble sending and receiving text messages. Put in air plane mode than off and it pushes them thru. Is there a fix to this? I have tried just about everything. I'd appreciate your thoughts
khuls - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 43
All Time: 2,059
