Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone Won't Charge Once Fully Discharged
You cannot get the phone to charge once its battery life has reached a certain level
Charging Cable Needs to be Replaced
The charging cable itself may not be working correctly. Consider purchasing a new cable.
Battery Needs to be Charged Externally
The battery level has become so low that the device will not charge anymore. One way to fix this problem is to charge the device externally by plugging the phone into a computer or other device. Charging the battery through the computer will allow the battery life to reboot, allowing you to use your normal charging cable again.
Battery Needs to be Replaced
The battery life of the device has reached a point that is too low for the device to be recharged. Another way to fix this problem is to replace the battery. After replacing the old battery with a new one, be sure to keep the battery life from getting too low. This way you can avoid having to replace the battery again because of the same problem.
Phone Won't Turn On
You cannot get the phone screen to turn on and display apps
Phone Needs to be Rebooted
No system is perfect and with enough use an issue can occur. Manually restarting the phone restarts all processes and makes sure they run right from the top. Hold the up or down volume button and the power button simultaneously until the phone vibrates or flashes a red light. Then hold the power button until the phone turns on.
The battery level has reached a point that is too low for the device to be recharged. To fix this, replace the battery. After doing so, be sure to keep your battery life up, so you can avoid having to replace the battery again because of the same problem.
Camera App Doesn't Work
You cannot get the camera to start when you tap the camera icon on your phone.
Phone Software is Out of Date
A bug in the software may be causing a problem with the camera app. Luckily developers are always coming up with software updates to fix reported problems. Hold the power and volume up button for one minute. Then try to update the phone software. Restart your phone again and try to open the camera app.
SD Card is Out of Memory
If there is insufficient memory on the phone an app won’t open to prevent problems with overwriting data. Remove the SD card out of your phone. Insert the SD card into a laptop or another phone and clear space on it. Restart your phone and re-insert the SD card. Then try to open the camera app.
Cache Data is Corrupt
Cache data is used by the camera to make it run more efficiently based on previous usage. Open the settings app on your phone. Navigate to ‘’Clear Cache’’ by finding the following sections:
Application>All>Camera>Clear Cache.
Restart your phone and then try to open the camera app.
Software is Corrupt
Sometimes apps installed on the phone can interact poorly with other apps causing them to malfunction. Software level issues are hard to pinpoint and resetting the phone is the only way to overcome it. Open the settings app on your phone. Navigate to factory reset:
System>Reset Options>Erase All Data(Factory Rest).
After resetting your phone make sure to not to restore from backup. Then try to open the camera app.
BIOS Needs to be Reset
BIOS is used to initialize hardware components on your phone, like the camera, when it starts up. Turn off your phone, remove the battery from the phone and wait for one minute. Reinsert the battery and turn it on. Then try to open the camera app.
Screen Doesn't Respond to Touch
You’re trying to use your phone while the screen is on but it doesn’t change
Software Issue
No system is perfect and with enough use temporary files build up in a system. Performing a soft reset will delete any of the temporary files that could be causing the issue. Hold the power button for about ten seconds. Once the screen turns off, release the power button.
Out of Date Software
Having the latest software update can fix problems with the touch screen if they are software related.
  • Open device diagnostics
  • Select software updates
  • Select device software
  • Select check for update
  • Follow prompts to install software update
Screen Protector or Case Interfering
The thickness of screen protectors or the design of some cases can affect the performance of the touchscreen. Remove the screen protector of the case and test to see if the screen is working. If this did not solve the issue, then remove the other component.
Application Cache Full
Clearing the application cache can free up space and improve device performance. Be sure to only clear application cache and not application data.
  • Select power usage
  • Select battery usage
  • Select application
  • Select app info
  • Select clear cache
Faulty Digitizer or Digitizer Connection
Grime and dust can collect on the inside of a device and prevent proper electrical connections. Disassemble the device and remove the logic board. Then soak your logic board in Isopropyl Alcohol of 91% purity or greater for 30-60 minutes. Remove the board and carefully brush the board to clean the connections. Once fully dry, reassembly and test the screen.
Faulty Display Assembly
If the above steps did not fix the problem then there is a problem with the display assembly and it needs to be replaced.
Phone Charges Slowly
You’re charging your phone but it’s taking to longer to charge than normal
USB Port is Obstructed
The USB port on the phone is where the charging cable fits in. There may be dust/oils/other substances that can cause improper contact between the charging cable and USB port. Turn the phone off and try brushing the port with a soft bristled toothbrush.
Power Cord has Loose Contact with Charging Port
Over time, the fit between the power cord and charging port can become loose. This improper contact limits the amount of current that can flow between the wall outlet and phone. Try purchasing a new power cord.
Phone Adapter is Bad
The adapter is the part of the charger that fits into the wall socket. The adapter can get damaged during use. Try purchasing a new adapter.
Battery Life is Low
As the phone goes through many cycles the battery loses its ability to hold charge and begins to lose some functionality. Try replacing the battery.
Charging Port is Broken
The USB charging port on the phone is where the charging cable fits in. This part can get corroded or bent and can hinder charging and poses a risk to the phone. Try replacing the charging port.
Author
with
Nicholas Leacox
1,739 Reputation
7 Guides authored
Cal Poly, Team S17-G3, Livingston Spring 2018 Member of Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Members
96 Guides authored
4 Comments
The voice won't run on and can't scroll the screen
Sheila Matson - Reply Share
can’t sign in
Keyana Pettet - Reply Share
how do you unlock the wallpaper app. so I can change it, on a zmax10 phone
bill albin - Reply Share
Battery was changed and lost at least 95% volume on everything. Bluetooth speaker is only way I can hear anything without straining my ears.
Debbie Campbell - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 24
All Time: 3,080
