ZTE ZMax Pro Charging Port Replacement
    1. ZTE ZMax Pro Charging Port Replacement, Back Panel Assembly: step 1, image 1 of 1
      • Flip the phone over so that the back panel of the phone is facing up.
      • Wedge the plastic opening tool between the black outer panel and the silver side panel.
      • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
      • Continue to do this around all sides of the phone until the back panel has popped all the way off.
      • Removing the back panel may make loud popping noises which is normal.
      Ask FixBot
    2. ZTE ZMax Pro Charging Port Replacement: step 2, image 1 of 1
      • Using your fingers, slide the SIM card all the way out of the phone.
      Ask FixBot
    3. ZTE ZMax Pro Charging Port Replacement: step 3, image 1 of 2 ZTE ZMax Pro Charging Port Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
      Ask FixBot
    4. ZTE ZMax Pro Charging Port Replacement: step 4, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
      Ask FixBot
    5. ZTE ZMax Pro Charging Port Replacement: step 5, image 1 of 1
      • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
      Ask FixBot
    6. ZTE ZMax Pro Charging Port Replacement: step 6, image 1 of 2 ZTE ZMax Pro Charging Port Replacement: step 6, image 2 of 2
      • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
      Ask FixBot
    7. ZTE ZMax Pro Charging Port Replacement: step 7, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
      Ask FixBot
    8. ZTE ZMax Pro Charging Port Replacement: step 8, image 1 of 1
      • Flip the phone over so that the screen is facing up.
      • Wedge the plastic opening tool between the screen and the rear panel.
      • Push up on the opening tool to separate the panel from the phone.
      • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
      • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
      Ask FixBot
    1. ZTE ZMax Pro Charging Port Replacement, Charging Port: step 9, image 1 of 1
      Buy
      Ask FixBot
    2. ZTE ZMax Pro Charging Port Replacement: step 10, image 1 of 2 ZTE ZMax Pro Charging Port Replacement: step 10, image 2 of 2
      • Use tweezers to peel off the tape at the bottom of the phone.
      Ask FixBot
    3. ZTE ZMax Pro Charging Port Replacement: step 11, image 1 of 1
      • Wedge the plastic opening tool under the charging port board at the bottom of the phone.
      • Push down on the plastic opening tool so the board pulls away from the phone.
      • Continue to do this around the charging port board until it comes all the way off the phone.
      • The board is glued to the case so make sure to work around all edges to ease removal. Trying to pull it away from one edge can cause damage to the board.
      • After removing the charging port, the adhesive will not have as strong of a hold on the new charging port. This should not be an issue. However, if the adhesive strength is negligible, you can consider buying adhesive and applying it before inserting the new charging port.
      Ask FixBot
11 other people completed this guide.
Nicholas Leacox
1,739 Reputation
7 Guides authored
Cal Poly, Team S17-G3, Livingston Spring 2018 Member of Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Members
96 Guides authored
11 Guide Comments
Very nice BUT where do you get the replacement charging port?
Anthony Kearns - Reply Share
Where can I bye the parts
John Anderson - Reply Share
“Buy” as in purchase not “Bye” as in see you later.
Thomas Heward - Reply Share
How much is it cost to fix it
anna lightsey - Reply Share
My charging port was 5.79 with free shipping at
James T. - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 72
All Time: 8,814
