Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
ZTE Jasper LTE Fails to Charge
The phone will not hold a charge or is having issues charging.
Faulty Battery
If the phone only powers up when the charging cable is plugged in and doesn’t hold a charge then try replacing the battery with this guide.
Faulty Charging Cable
Ensure the charging cable is plugged in to a working outlet and connected properly to the phone. If the phone doesn’t respond by showing that it is actively charging, then consider purchasing a new charging cable.
Insufficient Memory Storage
The memory storage of the SD card is full.
Too Many Files/Apps
The storage issue might be because it has all been used up. In that case, if possible, try deleting unnecessary files, applications, caches to free up memory storage.
Low Capacity Memory Card
If that is still not enough storage for you, consider purchasing a larger capacity SD card and installing via this guide.
Photos Are Distorted
Camera images are distorted, blurry, dark, or discolored.
Dust or Grime on Camera
Try wiping off dust or grime on the outside of the phone and camera lens with a microfiber cloth. If this does not solve the issue, then follow this guide on how to take apart the device to clean the inside of the lens.
Phone Software isn’t Up to Date
The issue might be because of the camera application isn’t functioning properly. Try updating the phone to the most recent software through these steps. From the main screen, tap the “Apps” icon. Slide the screen up to reveal more options and tap the “Settings” icon. Slide the screen up and tap “About phone”. Tap “Software Update”. Tap “Check for Updates”. Your phone will install any available updates, or “Your Software is Up to Date” will display. Tap “OK”.
Restart your phone through these steps. Press and hold the PWR/LOCK key on the top right of the device, and you should be prompted for a choice to “Power off.”, tap it, and then tap “OK.” To turn the phone back on press and hold the PWR/LOCK key until the screen lights up. Try the camera application again.
Broken Camera
The issue might have to do with the physical camera device in the phone—it has gotten old and stopped working, or has malfunctioned. Either way, consider replacing the camera with this guide here.
Speaker Doesn’t Emit Noise
No audio can be heard or the sound is distorted.
Bad Speakers
To determine which audio source has problems, try plugging a device into the audio jack. If the sound is clear and working, then try using the phone’s speakers. If the speakers sound muffled or is not working, look at the following guide for replacement.
Screen is Unresponsive
You are trying to use your phone while the screen is powered on, but nothing is responding to touch.
Software Issue
This issue could be related to out-of-date software, or a related problem. Try updating your software to the latest version through these steps. From the main screen, tap the “Apps” icon. Slide the screen up to reveal more options and tap the “Settings” icon. Slide the screen up and tap “About phone”. Tap “Software Update”. Tap “Check for Updates”. Your phone will install any available updates, or “Your Software is Up to Date” will display. Tap “OK”.
Then restart your phone through these steps. Press and hold the PWR/LOCK key on the top right of the device, and you should be prompted for a choice to “Power off.”, tap it, and then tap “OK.” To turn the phone back on press and hold the PWR/LOCK key until the screen lights up. Try the screen again.
Dust or Grime on Screen
Try wiping off dust or grime on the screen of the phone with a microfiber cloth. If this does not solve the issue, then follow this guide on how to replace the screen.
Dead Screen
This issue might be the result of the screen no longer working. Try restarting the phone through these steps. Press and hold the PWR/LOCK key on the top right of the device, and you should be prompted for a choice to “Power off.”, tap it, and then tap “OK.” To turn the phone back on press and hold the PWR/LOCK key until the screen lights up. Try testing the phone again. If no other solutions work, try replacing the screen with this guide.
Jeremy Douglass
197 Reputation
1 Guide authored
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 32
All Time: 583
