ZTE Jasper LTE Screen Replacement
    1. ZTE Jasper LTE Screen Replacement, Battery: step 1, image 1 of 1
      • Insert the spudger into the bottom left corner of the phone.
      • Use the spudger to loosen the back cover.
      Ask FixBot
    2. ZTE Jasper LTE Screen Replacement: step 2, image 1 of 1
      • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
      • Continuing to use tool, prop up the battery and remove it.
      Ask FixBot
    1. ZTE Jasper LTE Screen Replacement, Camera: step 3, image 1 of 2 ZTE Jasper LTE Screen Replacement, Camera: step 3, image 2 of 2
      • Remove nine 0.8mm Phillips #00 screws.
      Ask FixBot
    2. ZTE Jasper LTE Screen Replacement: step 4, image 1 of 2 ZTE Jasper LTE Screen Replacement: step 4, image 2 of 2
      • Remove the back cover by pulling upwards.
      • Removing the back cover may take a bit of force.
      Ask FixBot
    3. ZTE Jasper LTE Screen Replacement: step 5, image 1 of 3 ZTE Jasper LTE Screen Replacement: step 5, image 2 of 3 ZTE Jasper LTE Screen Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
      • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
      • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
      Ask FixBot
    1. ZTE Jasper LTE Screen Replacement, Screen: step 6, image 1 of 1
      • Disconnect all of these parts from the motherboard.
      Ask FixBot
    2. ZTE Jasper LTE Screen Replacement: step 7, image 1 of 3 ZTE Jasper LTE Screen Replacement: step 7, image 2 of 3 ZTE Jasper LTE Screen Replacement: step 7, image 3 of 3
      Buy
      • Remove the 0.8mm Phillips #00 screw from the bottom right.
      • Disconnect the gold pin by pulling upwards with the tweezers.
      Ask FixBot
    3. ZTE Jasper LTE Screen Replacement: step 8, image 1 of 3 ZTE Jasper LTE Screen Replacement: step 8, image 2 of 3 ZTE Jasper LTE Screen Replacement: step 8, image 3 of 3
      • Lightly disconnect the power button, volume button and the chip from the motherboard.
      • Be careful not to tear the volume and power button off the motherboard.
      Ask FixBot
    4. ZTE Jasper LTE Screen Replacement: step 9, image 1 of 2 ZTE Jasper LTE Screen Replacement: step 9, image 2 of 2
      • Lightly move clip back to release the motherboard.
      • Gently pull the motherboard away from the screen.
      Ask FixBot
2 other people completed this guide.
Anthony Sou
391 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 59
All Time: 590
