What screwdriver do I need to open my Xbox Series X?
A Torx 8 (T8) or Torx Security (TR8) screwdriver can remove the standard torx screws securing the case and components inside the Xbox Series X console.
Standard Torx vs. Security Torx
The screws that hold together the Xbox Series X and Series S are standard torx screws. Security torx screws, found in Xbox controllers and PlayStation consoles, have a "dot" in the middle which prevent standard torx screwdrivers from fitting. If you plan on opening an Xbox controller you'll want a torx security screwdriver on hand.
Standard Torx (Will open Xbox Series X,S)Security Torx (Will open Xbox Series controller and console)
Important
Follow iFixit's screwdriver best practices to ensure an optimal fit when removing screws. In general, use the largest driver size that fits snugly into the screw to avoid stripping the screw.
What screwdriver do I need to open my Xbox Series S?
A Torx 8 (T8) or Torx Security (TR8) screwdriver can remove the standard torx screws securing the case. A Torx 10 (T10) or Torx Security (TR10) is needed to remove the screws securing the components to the chassis inside the Xbox Series X console.
What other tools will I need to repair and clean my Xbox Series X|S?
Spudger
A spudger is suitable for prying off the Series X's back cover and handling small connectors.
A pair of precision tweezers can be useful when disconnecting delicate cables and removing the stickers that hide the screws on the outside of the console.
Evan Gattuso
25,938 Reputation
7 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Comments
Past 24 Hours: 43
Past 7 Days: 285
Past 30 Days: 1,495
All Time: 14,608
