What screwdriver do I need to open my Xbox controller?
Necessary: Torx Security 8 (TR8)
A TR8 Torx Security screwdriver can remove the fasteners securing Xbox 360 controllers and standard Xbox One and Xbox Series X|S controllers.
A Torx Security screwdriver is essential to opening your Xbox controller. The tip of the Torx Security (iFixit refers to it as a TR#) screw head has a small hole in the center which differs from a standard Torx screw head (iFixit refers to it as a T#). Torx Security screwdrivers can fit standard and security Torx screws. If you’re in a pinch, you can bypass these security screws with nothing but a small flathead screwdriver.
Standard Torx (Won’t open an Xbox controller)Security Torx (Will open an Xbox controller)
Note
The number and location of these screws vary for each model, especially for the Elite Series 2, so follow the correct Xbox Controller guide for your model to find the exact location of the screws. Depending on the age and condition of your bit, a Torx T9 or TR9 screwdriver may fit better.
Xbox Series ControllerXbox 360 Controller
Important
Follow iFixit's screwdriver best practices to ensure an optimal fit when removing screws. In general, use the largest driver size that fits snugly into the screw to avoid stripping the screw.
Optional: Torx 6 (T6)
You’ll also want to use a T6 Torx or TR6 Torx Security screwdriver to remove the standard Torx screws if you are replacing or modding other internal components like the motherboard or LED.
Note
Not every component in every controller will require a TR6 screwdriver, so check the appropriate repair guide for your controller.
What other tools will I need to mod, repair, and clean my Xbox controller?
Opening Tool
A specialized opening tool can release the strong plastic clips that secure the Xbox Series controller’s outside cover. Significant force is required to release them. Take your time to avoid damaging your controller.
Precision tweezers are useful when handling small parts inside the controller. Use these to cleanly remove the battery compartment sticker that hides a security screw without using your fingers or puncturing a hole in the sticker.
Spudger
A spudger is suitable for removing the Xbox 360 controller’s back case and for disconnecting small components.
Evan Gattuso
25,935 Reputation
7 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Comments
Past 24 Hours: 42
Past 7 Days: 253
Past 30 Days: 1,088
All Time: 34,422
