What screwdriver do I need to open my Xbox One?
Microsoft uses standard torx screws to secure the case and components of the Xbox One, Xbox One S, and Xbox One X:
  • The Xbox One requires a Torx (T8 or T9) or a Torx Security (TR8 or TR9) screwdriver and a T10 or TR10 to remove the screws that secure the components in the console.
  • The Xbox One S requires a T8 or TR8 and T10 or TR10 to remove the components from the metal interior casing.
  • The Xbox One X requires a T10 or TR10 to remove the screws securing the back of the case and other components to the metal interior case. A T8 or TR8 is needed to remove the screws holding the front circuit board to the upper metal case.
Standard Torx vs. Security Torx
The screws that hold together the Xbox One consoles are standard Torx screws. Security Torx screws, found in Xbox controllers and PlayStation consoles, have a "dot" in the middle which prevent standard Torx screwdrivers from fitting. If you plan on opening an Xbox controller you'll want a Torx Security screwdriver on hand.
Standard Torx (Will open Xbox One)Security Torx (Will open Xbox One controller and console)
Important
Follow iFixit's screwdriver best practices to ensure an optimal fit when removing screws. In general, use the largest driver size that fits snugly into the screw to avoid stripping the screw.
What other tools will I need to repair and clean my Xbox One?
A pair of tweezers can be useful when disconnecting delicate cables and removing the stickers hiding screws on the outside of the One X console.
Spudger
A spudger is suitable for disconnecting cables, connectors, and prying case clips throughout the console.
Evan Gattuso
25,935 Reputation
7 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Comments
O botão do de conectar ao Bluetooth do meu Xbox não tá querendo ligar, eu aperto o botãozinho e a bolinha branca do Xbox não começa a piscar.
Pedro Henrique M Ramos - Reply Share
O botão de conectar ao Bluetooth do meu Xbox one s não está fucionando, eu aperto ele e a bolinha branca do Xbox não pisca pra conectar ao controle.
Past 24 Hours: 9
Past 7 Days: 79
Past 30 Days: 331
All Time: 4,667
