Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Bread will not toast thoroughly, or at all
Heating component is not reaching a high enough temperature to toast bread.
Heating Component Does Not Receive Power
Check to be sure that the toaster is plugged in and there is no observable damage to the power cord. If no power reaches the heating component, this could be due to a bad electrical connection that may have occurred if the toaster was dropped or the wires could be corroded if they got wet. If the toaster is turning on at all, try checking the electrical connection with this guide.
Faulty Heat Dial Circuit Board
Check to be sure that the toaster is plugged in and there is no observable damage to the power cord. If the toaster is not responding to the toaster the heat dial circuit board could be fried. This could have happened due to water damage. If the toaster is not responding to the heat dial, try replacing the heat dial circuit board with this guide.
Slide Lever Malfunction
The toast control lever will not remain locked when pulled down or will not rise all the way up.
Faulty Slide Assist Plunger
If the toast will not remain locked in the toaster or will not pop up when the timer is done, the slide assist plunger may need to be replaced. Over time, the slide assist plunger may loose its' suction or get jammed which results in the slide lever being unable to reach the bottom of the divot, or the toast not rising when the timer is done. If this is the case, try replacing the Slide Assist Plunger with this guide.
Latch Malfunction
If the user is unable to push the lever into the locked position, this may be the cause of a latch malfunction. This can occur if the toaster was dropped or the lever was pushed down super hard. If the lever is unable to be pushed down, or if the lever is able to be pushed to the bottom of the divot, but will not stay secured at the bottom, try unjamming the latch.
Light Malfunction
Button lights will not turn on.
Faulty Light Component
If the lights on the toaster do not come on, then this could be results of the component breaking if the toaster was dropped, water damage, or the lights are simply burnt out. If lights for various buttons will not turn on while the toaster is plugged in and other toaster functions work, try replacing the light component with this guide.
Ryan Funchess
715 Reputation
5 Guides authored
Cal Poly, Team S22-G5, Maness Spring 2018 Member of Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Members
60 Guides authored
6 Comments
My bread will not toast thoroughly and takes two cycles on dial 7 to toast. Is it the rheostat?
Craig Carlson - Reply Share
Did you ever find and answer to this question? I have same toaster ame problem
Wolf - Reply Share
Yup same with me the thing just doesn't get hot
Erik Robertson - Reply Share
My knob broke off. I can't find the knob assembly part -- just the knob. Where can I get it?
TREEHUGGER - Reply Share
Wolf Gourmet 844 885-8770 will sell you replacement knobs or the crumb tray. Those are the only two parts they supply for repairing your Wolf toaster. Does anyone have any luck in repairing the slide assist plunger?
Todd Blake - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 66
All Time: 3,935
