Wolf Gourmet WGTR102S Electrical Connection Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
77
All Time:
1,585
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If no electricity flows through the toaster when plugged in, try replacing the electrical connection with this guide.
Tools
    1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Outer Shell: step 1, image 1 of 1
      • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
      Ask FixBot
    2. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 2, image 1 of 1
      • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
      Ask FixBot
    3. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 3, image 1 of 1
      • Remove the crumb collector located on the bottom of the toaster.
      Ask FixBot
    4. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 4, image 1 of 1
      • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
      Ask FixBot
    5. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 5, image 1 of 1
      • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
      • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
      Ask FixBot
    6. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 6, image 1 of 1
      • Remove the final 8mm screw in the slide lever.
      • The lever can now pull away from the entire unit.
      Ask FixBot
    7. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 7, image 1 of 1
      • Remove toaster's outer shell by lifting straight up.
      • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
      Ask FixBot
    8. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 8, image 1 of 2 Wolf Gourmet WGTR102S Electrical Connection Replacement: step 8, image 2 of 2
      • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
      • Remove the outer shell from the device.
      Ask FixBot
    1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Electrical Connection: step 9, image 1 of 1
      • Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
      Ask FixBot
    2. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 10, image 1 of 1
      • Use pliers to pull apart the three electrical connectors pictured in the graphic.
      Ask FixBot
    3. Wolf Gourmet WGTR102S Electrical Connection Replacement: step 11, image 1 of 1
      • Replace the electrical connectors.
      Ask FixBot
Ryan Funchess
715 Reputation
5 Guides authored
Cal Poly, Team S22-G5, Maness Spring 2018 Member of Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Members
60 Guides authored
1 Guide Comment
Ryan Funchess
Thank you for you work on this toaster. My customer is happy.
Adam Hunsinger - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 77
All Time: 1,585
