Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Touchscreen Problems
Touchscreen doesn’t respond to pressing buttons
Digitizer Connection Problem
The connection from the touch screen digitizer to the motherboard may be loose or dirty and needs to be reset.
Touchscreen Contact Cleaning
Phone loops the same song
The phone never stops playing the same portion of one song
Dying Batteries
If the song proceeds to loop, and there are no outward physical damage, there may be an issue with the batteries.
Battery Replacement
Device Has Water Damage
The device has been exposed to water either through spilling or drool. If this is the case, the phone is severely damaged and beyond repair.
Phone won’t turn on
Switching the power switch does nothing
Dead Batteries
If the phone will not turn on, and the power switch moves freely, you may want to replace the batteries.
Battery Replacement
Switch Issue
Assuming the batteries are working, then you may have an issue with the switch. If the switch won’t move back and forth, then it may have been damaged, and needs to be replaced.
Power Switch Replacement
Screen contact problems
If the batteries and the switch are working normally, then you may have issues with the contact points of the phone's screen digitizer. Assuming this is the issue, you will need to refer to the guide on replacing touchscreen contact points.
Phone turns itself on
The phone turns on without touching the power button
Misaligned Power Switch
If the power switch seems loose or won’t move back and forth, you may need to realign the switch.
Water Damage to Power Switch
If the switch seems to be working, and the phone remains on, then you may have had water (or drool) damage to the device. This may be fixed by replacing the power switch.
Misaligned Swipe Screen
The background screen may come in the package misaligned or it may become misaligned
Black or White Screen Visible
If the screen displays white or black when toggled all the way to the left or right you may need to realign the screen.
Screen Alignment
Sean Webb
384 Reputation
2 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2015 Member of USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Members
72 Guides authored
8 Comments
Tore the whole phone apart because the song was repeating. Turns out the batteries were just low : ( Oh well at least I fixed the problem. I just told my wife I fixed it didn't let her know what was wrong with it. Good reminder to check for simple solutions first
Evan - Reply Share
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - Reply Share
My son's phone keeps blacking out then turning how how do I fix this problem
rdukes - Reply Share
My daughters phone will turn on and swipe to enter app area but then once you press an app the screen blacks out…anyone else have this issue and managed to fix the problem?
Carity - Reply Share
Thank you! Changing the batteries fixed the loop issue
Jessica Dorado - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 24
All Time: 11,095
