Repairing VTech Touch and Swipe Baby Phone Screen Alignment
Views: 2.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
88
All Time:
2,134
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
This guide required
Tools
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: step 1, image 1 of 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: step 1, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
      Ask FixBot
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 2, image 1 of 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 2, image 2 of 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 2, image 3 of 3
      • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
      Ask FixBot
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 3, image 1 of 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 3, image 2 of 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 3, image 3 of 3
      • When reassembling, align the notch on the battery panel with the slot on the phone.
      Ask FixBot
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 4, image 1 of 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 4, image 2 of 2
      • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
      Ask FixBot
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 5, image 1 of 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 5, image 2 of 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 5, image 3 of 3
      • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
      Ask FixBot
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 6, image 1 of 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 6, image 2 of 2
      • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
      • Slide off the spring.
      Ask FixBot
    4. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 7, image 1 of 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 7, image 2 of 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 7, image 3 of 3
      • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
      • Lift up the black plastic piece.
      Ask FixBot
    5. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 8, image 1 of 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 8, image 2 of 2
      • Remove four 7.5mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    6. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 9, image 1 of 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 9, image 2 of 2
      • Remove the two buttons, noting how wires are placed for reassembly.
      Ask FixBot
    7. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 10, image 1 of 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 10, image 2 of 2
      • Lift the button board up and away to clear room for lifting the motherboard.
      • Tilt the assembly up but being wary that it is still attached to the front panel.
      Ask FixBot
    8. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 11, image 1 of 1
      • Slide the toothed slider towards you to remove.
      Ask FixBot
    9. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 12, image 1 of 1
      • To reassemble, align the two black lines together by moving the belt back and forth.
      • Once aligned reinsert the toothed slider at the exact point shown.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
Sean Webb
384 Reputation
2 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2015 Member of USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Members
72 Guides authored
1 Guide Comment
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 88
All Time: 2,134
