Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Frozen or Unresponsive Screen
The screen does not respond to inputs or is stuck on a single image.
Driver Error
Driver is installed but is unresponsive to the operating system.
Overheating
Overheated devices can cause the screen to lock up.
Overburdened RAM
Causes sluggish performance which may affect the speed of the device
Broken Screen
If the screen is not responding to any form of touch or button press, you may try restarting the device. If the device continues refusing to respond to inputs you may need to replace the screen.
Black Screen
The screen does not display even if the device can be turned on.
If the back light is malfunctioning the screen will not be able to properly display
Broken Screen
If direct impact is taken to the front of the device, damage can be done.
No Audio
No or garbled audio comes from the device when not using headphones.
Audio issues can be caused by a faulty speaker or connection.
Blockage
If areas of the speaker system are blocked with dirt or debris it can result in poor audio quality.
Low Battery Life
Battery drains rapidly without constant charging.
Charging Port Issues
The charging cord may be loose or the port may be full of debris. These would both cause problems with charging. This can be identified by the device stopping and resuming charging randomly. If the battery will not charge even with a clean charging port, the battery may need replacement.
If your tablet charges but does not stay charged, you may need to replace the battery.
Running too Many Apps
Using too much processing power can drain the battery much quicker.
Outdated Operating System
If the operating system is out of date it can run inefficiently and require more battery usage.
Slow Performance
Response of the device is noticeably slower than previously.
Using too much processing power by running too many or too intensive apps can noticeably affect performance.
Low Storage Space
Freeing up storage space can potentially lead to better performance if it was too low before
Storage Drive Damage
If the storage drive is physically damaged it may result in worse performance.
The software system is no longer receiving updates or edits from the manufacturer or developer⏎
Camera Malfunctioning
Broken Camera
If the camera is physically damaged it may need to be replaced
Overheating
Device gets too hot and may shut itself down.
A broken battery can result in high amounts of heat buildup
Casing Preventing Venting
The phone case can potentially prevent hot air from escaping, preventing the tablet from cooling down
The Device Won't Turn On
If the battery is damaged the tablet will not be able to turn on.
Broken Charger
It’s possible the charger is not functioning and must be replaced to properly charge the tablet.
A damage to the motherboard or its connections can prevent device functioning.
Author
with
Camila Garcia
51 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 26
All Time: 315
