Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet won't turn on
The tablet doesn't turn on when you press the power button.
Misaligned/dead batteries
Check that the batteries are correctly oriented. If they aren't, properly orient them. If the device still fails to power on, replace the batteries with a fresh pair. Refer to our Battery Replacement Guide if assistance is required.
Faulty internal wiring
It is possible that one or both of the black and red wires that connect your device's batteries to the main circuit board are detached. If this is the case, our Wire Replacement Guide will assist you in reattaching the wires.
Hard to see what is on display screen
If you are having trouble seeing what is on the main display screen, it is likely that your display screen isn't bright enough. It could also just be broken.
Brightness settings are low
While the device is on, press the button at the bottom right-hand side of the device that is directly below the "R" key. Pressing this button will allow you to change the contrast to your preferred level by increasing with the right arrow, or decreasing with the left arrow. Press the "OK" button twice to return to normal operation.
LED back light is off
Press the red button directly above the "OK" button to cycle through different colors and choose your child's favorite. This will assist in low-light viewing.
Faulty LEDs
The LEDs may be broken or disconnected, refer to our LED Replacement Guide for further help.
Display screen is broken
If none of the above solutions fix your problem, refer to our Screen Replacement Guide for further help.
Sound is too loud/soft
It is hard to hear sounds coming from the device, or the sound is uncomfortably loud.
Improper volume settings
While your device is on, press the button resembling a speaker on the left side. To increase sound volume, press the right arrow on the device. To decrease sound volume, press the left arrow on the device. Press the "OK" button once to return to normal operation.
Alternatively, the device's music can be individually toggled. Press the tools button (located directly below the R button). Then press "OK" , and press either the left or right arrow to toggle on or off, respectively.
Speaker is not working properly
If adjusting the volume settings does not fix your problems, you may need to replace or reconnect your speaker, see our Speaker Replacement Guide for help with this.
Devices freezes
The program freezes or does not respond to its buttons being pressed.
Interrupted power supply
Press the power button to turn device off. Remove batteries and let stand for 3 minutes. Place batteries back in device and press power again to turn on. Refer to our Battery Replacement Guide if assistance is required.
Author
with
Johnnie Cairns
522 Reputation
4 Guides authored
USF Tampa, Team 2-6, Sullivan Spring 2016 Member of USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 Members
72 Guides authored
12 Comments
My daughter got a Vtech My 1st Tablet as gift for Christmas. I have noticed that letter buttons e, f, g, h and i do not work. Please advise. Merry Christmas. Many thanks.
Clifford La Planche - Reply Share
My son got his kidibuzz for Christmas now the screen is black.. I can hear it come on but i can't see the screen
Michelle cottman - Reply Share
well my kiddibuzz volume doe not work how can i fix it
Aleah Harris - Reply Share
My daughter little apps tablet got freezed.
Its not turning on or off….
Farfal Kitchen - Reply Share
My kidibuzz does not work, l tried to charge it, reset it but the screen is all black like it doesn’t have battery
Roudha Alnuaimi - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 72
All Time: 7,521
