Up to 20% off select tools
VTech Little Apps Tablet Battery Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
107
All Time:
2,106
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide gives instructions on removing the device batteries. The device uses AA batteries. When replacing batteries, be sure that the plus (+) and minus (-) sides of the batteries are inserted as indicated on the device.
    1. VTech Little Apps Tablet Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      Ask FixBot
    2. VTech Little Apps Tablet Battery Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      Ask FixBot
Author
with
Johnnie Cairns
522 Reputation
4 Guides authored
USF Tampa, Team 2-6, Sullivan Spring 2016 Member of USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 Members
72 Guides authored
1 Guide Comment
Hello. Thank you for this tutorial. Do you know where I can find this speaker because by typing the reference LYS208R, it is not easy to find a merchant site (I am from France)
Antoine D. - Reply Share
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 107
All Time: 2,106
