Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone isn’t turning on
You have trouble turning on your device.
No battery
Check behind the case to ensure the battery is there. Be sure to check whether it if properly connected to the phone and that it is of the correct battery type.
Uncharged battery
If the phone isn’t turning on, it could be that it has been a while since the phone was turned on. Try plugging it into a socket via a charger to restore its charge.
Failed battery
As a device increases in age, the more likely it is for its battery to fail. This means that even if it were being regularly charged there would still be a sense of a constant need of power despite regular charging sessions.
Dark or dead pixels
Glass screen has cracks and is broken; also images might be distorted.
Glass Screen is broken
The only way to fix a broken screen is to replace it. Replacing a screen requires an elaborate guide to explain each step in detail. Click here for the guide.
Distorted Audio/No Audio from headphone jack
You have no audio or it doesn't sound clear.
Loose connection to headphone jack
Make sure you have a secure connection to the headphone jack
Headphone jack is faulty
If you have a secure connection and the audio is still distorted or there still is no audio. Then, the headphone jack needs to be replaced. For help replacing the headphone jack, check out our guide.
Rear camera isn't working
The camera on the phone's backside does not take pictures.
Camera lens is physically broken
The camera's lens could have a crack, or be broken in other ways. This affects the ability to take a picture and is best solved by replacing the entire lens.
Camera is disconnected due to faulty wiring
It is possible that there is a faulty connection somewhere inside the phone. Check if the screen remains blank or the picture quality differs in any significant way. To fix this problem you need to open the phone and reconnect or replace the wiring.
No audio when on a call
When on a call you cannot hear the other end.
Earpiece Speaker is broken
The earpiece speaker has been broken and needs to be replaced. Check out our guide for detailed steps on how to replace it.
Author
with
Esteban Almeida
329 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 606
