Unnecto Drone M Digitizer Replacement
    1. Unnecto Drone M Digitizer Replacement, Unnecto Drone M Disassembly: step 1, image 1 of 2 Unnecto Drone M Digitizer Replacement, Unnecto Drone M Disassembly: step 1, image 2 of 2
      • Place the phone facedown on a cleared work area
      • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
      Ask FixBot
    2. Unnecto Drone M Digitizer Replacement: step 2, image 1 of 1
      • Grip the top right corner of the battery.
      • Remove the battery by pulling it outwards.
      Ask FixBot
    3. Unnecto Drone M Digitizer Replacement: step 3, image 1 of 1
      • Remove the four screws on the back of the phone using a Philips 000 screwdriver
      Ask FixBot
    4. Unnecto Drone M Digitizer Replacement: step 4, image 1 of 1
      • Separate the frame evenly using a plastic opening tool.
      • Be careful, as the frame is thin and can break easily.
      Ask FixBot
    5. Unnecto Drone M Digitizer Replacement: step 5, image 1 of 2 Unnecto Drone M Digitizer Replacement: step 5, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
      Ask FixBot
    6. Unnecto Drone M Digitizer Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
      Ask FixBot
    7. Unnecto Drone M Digitizer Replacement: step 7, image 1 of 1
      • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
      • The white circuit is flimsy and securely glued to the frame.
      Ask FixBot
    8. Unnecto Drone M Digitizer Replacement: step 8, image 1 of 2 Unnecto Drone M Digitizer Replacement: step 8, image 2 of 2
      • Set aside the circuit board from the screen protector.
      Ask FixBot
    1. Unnecto Drone M Digitizer Replacement, Digitizer: step 9, image 1 of 2 Unnecto Drone M Digitizer Replacement, Digitizer: step 9, image 2 of 2
      • Replace the old plastic screen with the new one.
      • Reassemble the phone by following the steps in reverse order.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 62
All Time: 638
