Trouble retrieving satellite signal
The Garmin Nuvi 255W is having trouble finding a proper signal.
If you are having trouble obtaining a satellite signal, make sure your Nüvi is out of parking garages and away from tall buildings and tress. Then remain stationary for several minutes.
Broken Power button
The power button is not functioning properly.
If your power button is stuck or cracked, follow the directions in the link shown below to learn how to properly install a new power button into your device.
Garmin Nuvi 255W power button installation
Unable to charge device
The device is unable to recharge.
Battery does not recharge
If your battery does not recharge, most likely the battery has died and you need to replace it. Follow the directions in the link shown below to learn how to properly install a new battery into your device.
Garmin Nuvi 255W battery installation
Unable to charge the device in a vehicle
First, make sure your car is turned on while you are trying to charge your nüvi. The device will not charge if the vehicle is not supplying power. Also, make sure your device is out of direct sunlight as it will only charge between 32 and 113 degrees F. If your device still won't charge check the fuse in the power cable.
Malfunctioning speaker
The speaker of the Garmin Nuvi 255W does not produce desired sounds.
If your speaker does not produce any sound or produces unnatural sounds, follow the directions in the link shown below to learn how to properly install a new speaker into your device.
Garmin Nuvi 255W speaker installation
Clearing used data for the device
This will clear all data from the device.
To clear all the data on your nüvi hold your finger on the lower-right corner fo the nüvi screen while it is turning on. Keep your finger pressed until the message appears. touch "Yes" to clear all user data.
Unresponsive touch screen of the device
The touch screen of the Garmin Nuvi 255W is unresponsive.
Clean the touch screen
If the touch screen is unresponsive make sure that is clean. Use a soft, clean, lint-free cloth. Use water, isopropyl alcohol, or eyeglass cleaner, if needed. Apply the liquid to the cloth, and then gently wipe the touch screen.
Replace the touch screen
If touch screen is not functioning properly or is defective, follow the directions in the link shown below to learn how to properly install the touch screen into your device.
Garmin Nuvi 255W touch screen installation
Computer cannot detect the device
The Garmin Nuvi 255W cannot connect to the computer.
Using the USB cable
To get your computer to detect your nüvi, first, unplug the USB cable from your computer. Then, turn off the nüvi. Lastly, plug the USB cable into the USB port on your computer and into the nüvi. The nüvi should automatically turn on and go into USB mass storage mode. Ensure your nüvi is connected to a USB port and not a USB hub.
Timothy
76 Reputation
3 Guides authored
Cal Poly, Team 9-3, Regan Winter 2012 Member of Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Members
48 Guides authored
13 Comments
How do I replace lost Garmin USB cable?
Nick Bradley - Reply Share
tried everything said here above but nothing works;
computer still cannot detect my device
any other solution?
wimderuytter - Reply Share
Need to download Garmin Express to detect GPS Unit
cheadler - Reply Share
My 255W says:"No detailed maps found that support routing."
Tom Parr - Reply Share
I am running MacOS 10.11.6 on my iMac. When trying to update my maps on my nevi 255W, the device is not recognized by the computer. I am using a brand new cable (working because my nevi is charging) plugged directly into a USB port on the computer, Does anyone have any suggestions?
Mark Walter - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 37
All Time: 29,030
