Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Freeze on Startup
I just went to turn it on but now its frozen!
Hard Reboot
We have noticed that this problem has been encountered by many people especially after their device updates. One way to possibly fix this problem is to make sure that it isn't possible to reset the tablet while it is frozen. Hold the power button down for a minute or two.
Reinstall Operating System
If hard rebooting the device didn't correct the problem then it may be that there is an issue with your operating systems. If this is the case you will need to reinstall your operating system to correct this.
Motherboard may be faulty
If a hard reboot or reinstalling the OS doesn't work then there may be a problem with the motherboard. If this is the case then follow this guide to help you replace it.
Device doesn't turn on
I have tried to turn on my device but it won't activate.
Battery may not be charged
If the battery is not charged it may cause the screen to freeze up before it dies. Check and see if when it is plugged into a charger if the screen displays the charging icon.
Charger may be faulty
If the device will not charge then the problem could be that the charger you have may be faulty. Try charging a similar device if you have one or a friend's device and see if it charges. If it does not then you will need to get a replacement charger.
Battery may be faulty
If you attempt to charge the battery with a working charger and that does not work then you might need to replace the battery. Follow this guide to help you.
Speakers are too low
The speakers on my Tablet are not as loud as they should be.
Volume is set too low
Check if the volume setting on the tablet is too low. If not then the problem may be an internal issue.
Speaker may be dirty
Sometimes dust can get inside the panel from the opening on top of the speaker as well as any small openings around the edge of the tablet. Open the back panel of the tablet and check to see if the speaker cover or speaker itself are dirty. Use our back panel replacement guide to help you clean the speaker.
Speaker is faulty
If you have checked the possible causes above and the speakers are not working properly then the speakers might be working efficiently entirely. Use this guide here to help you replace the speaker.
Tablet operates too slow while on the internet
While on the internet the tablet slows down and doesn't run as fast as it should.
Too many pages open at once
With this device too many pages or apps open and running at the same time will cause the Stealth-10 to slow down. For peak performance, make sure to close all web pages that you do not want to use.
The device feels warm to the touch
I am concerned that my device may be overheating
Excessive use of device
If you use the device for multiple hours at a time and/or use the device while charging it can overheat. To prevent this when the device starts to overheat a bit then turn it off and let the device rest. Also leaving the device off when charging will help as well.
Too many apps running at once
This device can overheat as well when multiple applications are running at the same time. To prevent this make sure that apps you are not using are not running and if they are to close them.
Author
with
Brandon Ferreira
324 Reputation
1 Guide authored
UMass Dartmouth, Team 1-4, Miles Fall 2015 Member of UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Members
72 Guides authored
6 Comments
Trying to go yo Google play store and keeps asking "do you want to add an existing account or create a new one? No sure what to do.
jadooley - Reply Share
my trio stealth 10 always says google play has stopped as all my apps do i push ok but it dosent work
Jessica Ewing - Reply Share
left side want respond stop working
cjwilliam92 - Reply Share
All my apps say stoped . How to fix this problem? Can't open anything. Screen freezes upon opening it should I what can I do or should I just buy a new one
Barbara Bennett - Reply Share
Trying to factory reset a Trio stealth -10. I have pressed and held the power button and the volume down button, went to factory reset, selected yes, but it keeps freezing at Formatting data. How do I fix this?
Mike Clomts - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 29
All Time: 5,508
