Trio Stealth-10 Speaker Replacement
  1. Trio Stealth-10 Speaker Replacement, Back Panel: step 1, image 1 of 1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Speaker Replacement, Speaker: step 2, image 1 of 1
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Speaker Replacement: step 3, image 1 of 1
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
Daniel Coleman
643 Reputation
5 Guides authored
UMass Dartmouth, Team 1-4, Miles Fall 2015 Member of UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 54
All Time: 488
