Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tom-Tom Will Not Power On
No matter what you do, you can't get your Tom-Tom to turn on.
Power Button Not Held Long Enough
Before trying to take apart your device, try holding down the power button for at least five seconds. The power button should light up. If the device still doesn't turn on, continue reading.
Device is Not Charged
The device may need to be charged. Plug the device into a power outlet with a charger you know works, and then hold the power button in for five seconds.
Drained/Bad Battery
The battery may be faulty or no longer holds a charge. Follow our guide on replacing batteries to fix this issue.
Broken Display
The device may be on, but nothing will appear on the screen. Follow our screen replacing guide to learn how to fix this issue.
Cant Find GPS Signal
When the GPS cannot calculate route, usually due to bad signal.
Blocked Signal
Make sure device is near window or outside of car to get maximum possible signal. Once this happens your route should be calculated. Be patient as it may take a couple of minutes to find the signal.
Out of Date Software
Make sure all software is up to date. This will be talked about more in the software section however there may be with devices signal if the software is not up to date.
Device is Unresponsive
The device is not reading any input and/or is stuck on one screen.
Device is Frozen
Hold down the power button which is located on the top of the device. This will turn off the GPS. Once it is completely off wait about five seconds before repressing the power button to turn it back on.
Battery Drained
If the power button isn't working, the battery may be drained. By plugging the TomTom back into a power outlet the battery can be charged. If the device only works when plugged in the battery may need to be replaced. Refer to our Battery Replacement Guide.
Device Needs Factory Reset
If the device still does not respond after powering on and off, a factory reset may be required. Use a paper clip to press the reset button for no less than 15 seconds to reset the device to factory settings.
Device Remains Unresponsive
If the device still doesn't work, contact TomTom with your issue and send the device back, as the touchscreen component may be faulty.
Screen is Black
No images are shown with a black screen.
Not Powered On
Ensure that the device is plugged into a working outlet and attempt to turn on the device again. If the device does not power on at all, refer to the "Tom-Tom will not power on" section. Otherwise, if lights are coming on but the screen is still black, continue other solutions in this section.
Faulty Software
The software may be faulty, leading to the black screen, especially if you just updated your software.
If the device still has a black screen after updating the software a factory reset may be required. Use a paper clip to push the reset button for 15 seconds to reset the device to factory settings. Note : a software update will most likely be required after this step.
Device Wont Charge
Device cannot and will not charge
Broken Charger
One problem is the charger could be damaged from extensive use. Replace this charger from your local device store or through this link http://www.ebay.com/itm/like/18154466941....
No Power Source
Sometimes device could be plugged into a faulty outlet that does not have power going to it. Try another outlet and it should work.
Author
with
Mathew Fleurent
125 Reputation
1 Guide authored
UMass Dartmouth, Team 4-4, Catania Fall 2015 Member of UMass Dartmouth, Team 4-4, Catania Fall 2015
UMASSD-CATANIA-F15S4G4
4 Members
60 Guides authored
4 Comments
I have tomtom 1605tm. Screen is not responding correctly. For example, if I press the letter F, the letter to left, D, is displayed. If I press the < Back Arrow, all I get is - Dash. I have tried turning off, waiting over 5 seconds, then turning back on, but problem persists. So frustrating! Any suggestions?
cajun.yankee - Reply Share
My 1605 rolls from one screen to the next and continues to do this, how can this be stopped?
Ben Jones - Reply Share
I have VIA 1605 with both in car and in house charger cords. BOTH cords are loose when plugged into unit and will discontinue charging unless the plug is help in place by hand. Can charge connection in unit be damaged somehow ? It is unlikely that BOTH cords are faulty at the same time. Suggestions please? Thanks. logannaftel@gmail.com
Logan Naftel - Reply Share
Traffic RDS not finding radio signal
Chick - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 2,233
