Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Will Not Turn On
No matter how much you push the power button, the device remains inactive.
Unresponsive Power Button
Hold down the power button for several seconds, if done correctly the screen should power down. Wait for 30 seconds before turning the device back on. Try this several times. The power button may be slightly off or “sticky”. While this is probably not the problem, it’s always worth a try before moving on.
The Battery may be Drained/Dead/Uncharged
Attempt to charge the device using the adapter for a wall outlet. Charging the device using a usb cord plugged into a computer will not provide the necessary power to charge the device.
If the device still does not respond, the battery will need to be replaced. Please refer to our Battery Replacement Guide to replace the battery with a new one.
Poor Display
If the tablet seems to be charging but the screen is not on or is too dark, the device may need a replacement screen.
Please refer to our Screen Replacement Guide to replace the the screen.
Unresponsive Motherboard/ Motherboard Crashed
If the display and the battery are not causing the problem, the motherboard may need to be replaced.
Please refer to our Motherboard Replacement Guide to replace the motherboard with a new one.
Device Will Not Stay Charged
After charging your device, it dies in a very short amount of time.
Battery Being Drained Quickly
Check if you have any apps opened. Having too many apps can cause the battery to drain faster.
Close out the apps>Connect the device to a charger>Try using the device after it's fully charged.
If the device dies too quickly, you may want to replace the battery with a newer one. Please refer to our Battery Replacement Guide for the necessary steps
Battery Lost Ability to Hold Charge
The battery has become less effective as it has aged and needs to be replaced.
Please refer to our Battery Replacement Guide in order to replace the battery.
Frozen Screen
The screen is not responsive to taps and gestures.
The Screen is Not Clean
If your device's screen is dirty take a clean cloth and gently wipe the screen off. Once it is cleaned your device should respond to taps and gestures.
Application is Delaying the Device’s Responses
If applications that you've installed on your device are causing a delay in your device, go to >Settings> Apps. Here you can select which application you wish to uninstall or deactivate in order to fix any delays your device is experiencing.
Software Issues
Press and hold the power button along with the volume down until the screen shuts off >Wait at least 10 seconds before turning your device back on >Afterwards, turn the device back on, holding the volume up button >Navigate to Wipe Data/Factory > Click "Yes" (Keep in mind this will delete all data on the tablet)
*Be sure to back up your data before wiping the device.
Wait for tablet to reboot and turn on.
Poor Screen Resolution
There may be some dust buildup inside the device.
Please refer to the Screen Replacement Guide in order to safely remove that screen for cleaning or to replace the screen.
No Sound
You turn the volume up on a new YouTube video, but no sound comes from the device.
Poor Speaker Quality
Try using different applications to check if only specific platforms output audio.
If nothing works, please refer to our Speaker Replacement Guide to replace the speaker with a new one.
Camera has Poor Quality Lens/Will not Take Pictures
You go to take a picture and the camera immediately crashes or there is a giant crack right in the middle of the lens.
Camera App Issue
Try opening the camera app.
If you can see an image from the camera, the tablet may just need to be restarted.
Poor Camera Quality/Resolution
If no image is shown in the camera app or there is a crack in the image, the camera will need to be replaced.
Please refer to our Camera Replacement Guide to replace your old camera with a new one.
Application Not Working
The tablet freezes or directs you to the home screen once you open the app.
Internet is Not Connected
Some apps cannot operate without internet connection.
Go to Settings > Wi-Fi, to check if you're connected.
If you are not go to Settings >Wi-fi> Select the Wi-Fi network you wish to connect to (Keep in mind some may need passwords to connect to).
Apps Not Installed Correctly
The app may not work if it was not installed correctly from the Googleplay.
This can be solved by deleting the app and reinstalling it.
Go to Setting > Apps > Locate the app > Press uninstall, then the app can be reinstalled from Googleplay.
App is Out of Date
Some apps can only be used when it is updated.
Go to Googleplay > Search the app > Check to see if application needs an update > Click "Update"
Proceed to restarting your tablet to ensure everything is updated.
System is Conflicting with the App Temporarily
Press and hold the power button along with the volume down until the screen goes off.
Afterwards, turn the device back on, holding the volume up button.
Author
with
Kevin Dennis
184 Reputation
1 Guide authored
USF Tampa, Team 2-1, Sullivan Spring 2016 Member of USF Tampa, Team 2-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G1
4 Members
72 Guides authored
7 Comments
System Fails to update why is that?
Allen Worple - Reply Share
hi I am getting a communication error when log in to Google
heidi archer - Reply Share
When I first got my tablet half the screen had a mesh-like gridrr
I have since learned that this is a function termed "Intelligent Backlight" in DEMO mode. To turn it off and restore your screen to normal, go to SETTINGS/DISPLAY/INTELLIGENT BACKLIGHT IN DEMO MODE/ Click that option to turn off DEMO MODE. Your screen should now display normally.
Chet DeBiaso - Reply Share
I've been trying to turn it on and it keeps resetting before it even turns on. It keeps saying “caused by misoperation, the system is going to make recovery“ it then goes to a screen where it says erasing with the android symbol before restarting the process all over again…what do I do to fix this!?
mary.kade.rocks - Reply Share
I only had 3 apps downloaded and it would come up no more storage. Its really slow. I don't like it.
Brandy McDonald - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 34
All Time: 3,499
