Up to 20% off select tools
Tagital T7X Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
83
All Time:
692
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The front and back cameras in this tablet are connected as one piece. Both cameras have to be replaced if either one is broken.
    1. Tagital T7X Camera  Replacement, Case: step 1, image 1 of 3 Tagital T7X Camera  Replacement, Case: step 1, image 2 of 3 Tagital T7X Camera  Replacement, Case: step 1, image 3 of 3
      • Place the Tagital T7X on a sturdy surface.
      • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
      Ask FixBot
    1. Tagital T7X Camera  Replacement, Camera: step 2, image 1 of 3 Tagital T7X Camera  Replacement, Camera: step 2, image 2 of 3 Tagital T7X Camera  Replacement, Camera: step 2, image 3 of 3
      • Use a spudger to hold the cameras in place.
      • Gently pull the black tape away using your finger.
      Ask FixBot
    2. Tagital T7X Camera  Replacement: step 3, image 1 of 3 Tagital T7X Camera  Replacement: step 3, image 2 of 3 Tagital T7X Camera  Replacement: step 3, image 3 of 3
      • Remove the ribbon cable from the motherboard.
      • Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
      Ask FixBot
    3. Tagital T7X Camera  Replacement: step 4, image 1 of 3 Tagital T7X Camera  Replacement: step 4, image 2 of 3 Tagital T7X Camera  Replacement: step 4, image 3 of 3
      • Gently pull the ribbon cable away from the motherboard.
      • Don't be afraid to use some force to pull the ribbon cable.
      Ask FixBot
Author
with
Hanlong Chen
265 Reputation
2 Guides authored
USF Tampa, Team 2-1, Sullivan Spring 2016 Member of USF Tampa, Team 2-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 83
All Time: 692
