Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device not turning on
Your device is not turning on.
Battery has no charge
If your device is not turning on, the internal battery may need to be charged. To do this, plug the microUSB charging cable into the charging port on the tablet and use the adapter for a wall outlet. Allow the tablet about 4 hours to charge fully. If the device is still not powering on, try using a wall outlet, or try a different charger, as one of these may be faulty.
Faulty battery
If your tablet still will not power on and you know that the charger works, the internal battery may be faulty. You can fix this by replacing the battery. Refer to the Battery Replacement Guide to remove and replace the battery.
Screen is broken
It is possible that the device is turning on, but the screen may be broken preventing it from displaying an image. In this case, refer to the Screen Replacement Guide to replace the touch screen.
Power button is broken
It is possible that over time the power button has been worn down or broken preventing it from being able to be powered on. In this case, refer to the power button Replacement Guide to replace the button.
Device not charging
Even after connecting your device to its charger, it will not charge.
Device is not properly plugged in
If the device will not charge check all the charger connections.  Check the connections between the device and the charging cord.  If the device still will not charge, check the connection between the charging cord and the computer or wall adapter.  If when plugged into the wall adapter the device still fails to charge make sure the wall adapter is correctly plugged into the wall outlet. If the issue persists try a different wall outlet.  If the device is still not charging a faulty charger may be the issue.
Faulty charger
To identify a faulty charger first try charging the device in a wall outlet. If the device is not charging try a second wall outlet.  Remove the wall adapter from the charger and plug into a running laptop. If the tablet charges when connected to the laptop then the wall adapter is faulty. If the tablet still fails to charge then try a different charging cable.  If the tablet fails to charge than the micro usb board may be bad or the battery.
Faulty battery
The battery may be bad if the device fails to charge, if the device run time has been decreasing, if the device is only operable when connected to the charger.  If the device exhibits these symptoms see the Replacement Guide for replacing the tablet's battery.
Faulty micro usb board
The micro usb board may be bad if the device fails to charge or transfer data using the charging cable. To identify a faulty micro usb board use a good charging cable to transfer data from the tablet to a laptop. If the device fails to transfer data or charge when connected to the laptop the micro usb board is faulty.  See the repair guide for replacing the micro usb board.
Frozen or unresponsive screen
Your device screen is unresponsive to touches and gestures or it is frozen entirely.
Touch screen is broken
The touch screen may be broken, causing it to be unresponsive to touch. To fix this issue see the Touch Screen Replacement Guide.
Device is frozen
The device itself may be frozen and should be restarted. Gently press and hold the power button to turn it completely off, and then turn it back on.
The screen is dirty
If the screen of your device is unresponsive or frozen, it may be caused by an accumulation of dirt or debris on the touch screen. Use a clean cloth to gently wipe the screen down.
Poor photo quality
The camera on your device is consistently taking poor quality photos, or the photos turn out black.
Camera lens is dirty
If you notice that the quality of your photos is poor, the camera lens may be dirty or smudged. Use a clean microfiber cloth or other lens cleaning wipe, and gently rub the lens of the camera using circular motions. For stubborn spots, use a cotton swab dampened with distilled water. Do not blow on the camera with your mouth, as this could result in more debris on the lens.
Camera lens is obstructed
The camera lens may be obstructed by an object such as a tablet case. Make sure that all objects are clear of the camera’s view.
Camera app is glitched
If the problem persists, there may be a software glitch. Try restarting your device.
Broken camera
If the photos are still poor quality, or the pictures turn out distorted or black, the camera may be damaged or the lens is cracked. In this case, follow the Camera Replacement Guide to replace the camera.
Screen too dark
The screen on your device is dark and hard to read.
Brightness is set too low
It may be that the screen is dim due to the brightness setting. Open the tablet settings, go to display options, and adjust the screen brightness.
Battery charge is low
A low battery will cause the screen to dim in order to conserve battery life. Simply plug the device into a charger to resolve this issue.
Author
with
Destin Dawsy
328 Reputation
2 Guides authored
USF Tampa, Team 14-5, Eyestone Fall 2016 Member of USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
4 Members
60 Guides authored
5 Comments
On my tablet it keeps popping up Google play services has stopped . When I push it ,it repeatedly keeps coming back ? What do I do ?
Cynthia Orange - Reply Share
My T10 tablet flashes altice powered by android for two-three seconds then goes blank. It does this over and over no matter how I try the power and volume buttons.
Matthew Dobranski - Reply Share
Screen is black and will not show image. How can this be fixed??
vjmcguire - Reply Share
My grandson tablet is stuck on the screen with the robot and will not shut down
Margaret Johnson - Reply Share
Try to factory reset the tablet, if this doesn’t work than you will have to flash the ROM.
William M Midgett - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 33
All Time: 3,754
