Up to 20% off select tools
Tagital T10 Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
99
All Time:
827
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Your tablet is equipped with a rear-facing and front-facing camera that is capable of taking photos and capturing video. Deterioration over time or through rough handling may cause the camera to become too damaged to take photos. To fix this, you must replace the camera.
    1. Tagital T10 Camera Replacement, Camera: step 1, image 1 of 1
      • Always make sure your device is completely powered off before performing repairs.
      • Remove the two 4 mm Phillips head screws at the top of the device.
      Ask FixBot
    2. Tagital T10 Camera Replacement: step 2, image 1 of 1
      • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside.
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
      Ask FixBot
    3. Tagital T10 Camera Replacement: step 3, image 1 of 1
      • Pull the black tape away so that the rear-facing camera is no longer attached to the device.
      Ask FixBot
    4. Tagital T10 Camera Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Pull off the plastic camera cover with the tweezers so that the front-facing camera can move freely.
      Ask FixBot
    5. Tagital T10 Camera Replacement: step 5, image 1 of 1
      • Locate the small ZIF connector that connects to the cameras.
      • Use the plastic prying tool to pull up the black tab, so that the filament is released. Carefully pull the filament out so it is moving freely.
      • The camera can now be lifted from the device.
      Ask FixBot
Author
with
Destin Dawsy
328 Reputation
2 Guides authored
USF Tampa, Team 14-5, Eyestone Fall 2016 Member of USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 99
All Time: 827
