Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Wobbles During Flight
As soon as you take off it begins to wobble and progressively gets worse until it crashes.
Broken Gyro
The gyro most likely broke when it fell or the top rotors hit an object. Follow the Syma S107 Gyro Replacement Guide to solve the issue.
Rotates While Hovering
Hovers fine and you've reached the limit of adjustment on your controller but it still rotates left or right without touching the controller.
Bad Rotor Motor
One of the main rotor motors is weak or going bad causing the two main rotors to rotate at different speeds. See the Syma S107 Rotor Motor Replacement guide to replace the motor.
Won't Turn On
You've charged your S107, but when you turn it on no lights flash.
Bad Battery
The battery could be dead from quickly charging and discharging too many times. Also, the battery wires may have been broken or disconnected for the circuit board. Follow the Syma S107 Battery Replacement guide to install a new one or reconnect the wires.
Bad Circuit Board
The circuit board may have been shorted or faulty from the supplier. Follow the Syma S107 Circuit Board Replacement Guide to install a new one.
Author
with
Christopher Smith
305 Reputation
1 Guide authored
USF Tampa, Team 1-31, Donnelly Fall 2014 Member of USF Tampa, Team 1-31, Donnelly Fall 2014
USFT-DONNELLY-F14S1G31
1 Member
12 Guides authored
14 Comments
I just bought a S107g. Right out of the box I turned it on and the light lite up. Added battery's to the controller and just tested it to see if it worked. The blades spun. Tried it again quick as to not take off. All looked good. Tried it a third time to get lift and had no response at all. Lights in the front are on and the led on the R5 board is on. Did a full charge from the controller. Still no response. Any ideas? Did the board short out?
Mike - Reply Share
Ours worked well for exactly one day …. and then suddenly we had the same problem as you. The blades would spin but it just will not lift off, as if it no longer has enough power. Were you able to solve your problem and if so how?
Jim Albritton - Reply Share
Flew this for a total of less than 5 minutes.  After one *VERY* soft crash on grass, the bottom set of blades stopped turning and the motor sounds like it’s working or clogged or something.  The gears inside that are connected to the bottom wings don't appear to be spinning at all.  Without the bottom wings active, the helicopter doesn’t generate enough lift and won’t go airborne.  Halp!
Arthur - Reply Share
We are experiencing the very same thing! Soft crash landing and bottoms rotors won’t spin
Brittany Pigeon - Reply Share
What do I do if it wobbles during takeoff and sometimes it just randomly stops and goes down low even though it’s fully charged will new parts help and tell what parts I need it also has a Brocken wing.
jcm.cool - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 102
All Time: 23,057
