Up to 20% off select tools
Syma S107 Gyro Replacement
Views: 16K
View statistics:
Past 24 Hours:
6
Past 7 Days:
27
Past 30 Days:
155
All Time:
16,302
Comments: 6
6 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Replace the the gyro on your Syma S107 so that it stops self destructing.
    1. Syma S107 Gyro Replacement, Counterweight Bar: step 1, image 1 of 2 Syma S107 Gyro Replacement, Counterweight Bar: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
      Ask FixBot
    2. Syma S107 Gyro Replacement: step 2, image 1 of 2 Syma S107 Gyro Replacement: step 2, image 2 of 2
      • Remove the counterweight bar by removing the screw.
      • One 10.1mm Phillips #0.
      Ask FixBot
    3. Syma S107 Gyro Replacement, Gyro Carriage: step 3, image 1 of 2 Syma S107 Gyro Replacement, Gyro Carriage: step 3, image 2 of 2
      • Remove the gyro carriage by removing the following screws:
      • Two 5.6mm Phillips #0.
      • When reinstalling these screws make sure to line up one screw with the keyway on the main rotor shaft.
      Ask FixBot
    4. Syma S107 Gyro Replacement: step 4, image 1 of 2 Syma S107 Gyro Replacement: step 4, image 2 of 2
      • Gently remove the broken gyro carriage by pulling up.
      • Remove blade assembly by simply sliding it up and off the shaft.
      Ask FixBot
    5. Syma S107 Gyro Replacement, Blade Carriage: step 5, image 1 of 3 Syma S107 Gyro Replacement, Blade Carriage: step 5, image 2 of 3 Syma S107 Gyro Replacement, Blade Carriage: step 5, image 3 of 3
      • Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
      Ask FixBot
    6. Syma S107 Gyro Replacement: step 6, image 1 of 2 Syma S107 Gyro Replacement: step 6, image 2 of 2
      • Remove the blades from the blade carriage by removing the following screws:
      • Two 4.7mm Phillips #0.
      Ask FixBot
    7. Syma S107 Gyro Replacement: step 7, image 1 of 2 Syma S107 Gyro Replacement: step 7, image 2 of 2
      • Remove the following screws:
      • Two 4.5mm Phillips #0.
      • Make sure to remove any broken plastic pins before reassembling the components.
      • You will have to slide the two halves of the blade carriage over the pins on the gyro carriage first when reassembling.
      Ask FixBot
7 other people completed this guide.
Author
with
Christopher Smith
305 Reputation
1 Guide authored
USF Tampa, Team 1-31, Donnelly Fall 2014 Member of USF Tampa, Team 1-31, Donnelly Fall 2014
USFT-DONNELLY-F14S1G31
1 Member
12 Guides authored
6 Guide Comments
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Patrick haymer - Reply Share
Cheers thanks too this page I fixed problem  great ,  Martin
Martin Worboys - Reply Share
Same here, incidentally where can I get replacement batteries please? Also have a “Picolo” heli with a bad feedback IC , supposedly this part can also be replaced on some units as its a soldered vertical board on the main.
Andre - Reply Share
Thank you! Took forever to find an answer to my problem! Now very obvious thanks to you. My sanity is restored! HaHa!
CRC 04/04/2021
Chris - Reply Share
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Adam Leavesley - Reply Share
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 155
All Time: 16,302
