Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Phone Is Not Charging
The phone is not charging when plugged in to the USB Charging Cable.
There Are Foreign Substances in the USB Port
If there is any outside substance on your charging cable, it can interfere with the USB fitting perfectly into your phone, therefore preventing charging. Make sure that there is no moisture on or in the USB port. Also use a gentle object like a paintbrush or a toothbrush to remove any dirt or lint that may be in the USB port.
The USB Charging Cable Is Damaged
If your USB Cable is damaged, that means that current is not able to flow through completely, which is why your device is not charging. Your USB Cable is damaged if the plastic coating has come off and the cable has wires that are frayed. This can be temporarily fixed with electrical tape, but the long term solution is buying a new one.
The USB Charging Cable Is Incompatible
Using a third-party USB charging cable that is incompatible with your phone can be a reason that your phone is not charging because current is not able to flow. Make sure that you are using the original charging cable for your phone. If you do not own that cable, use a USB charging cable that is certified by Sony to be compatible with your phone.
The Applications on Your Phone Are Preventing It from Charging
There may be apps on your phone that you have downloaded that are preventing your phone from charging. If your phone has enough battery, put it in safe mode, which will disable all third-party apps so that the only apps running are the ones from Sony. To put your phone in Safe Mode, do the following:
  • Step 1: While the device is on, press and hold the power button
  • Step 2: Touch and hold the power off option until your phone is shut down
  • Step 3: The Safe Mode prompt will appear on your phone. Tap OK. Your phone will restart in Safe Mode
  • Step 4: Plug your phone into your charger
If your phone charges, some third-party apps are the problem and you will need to uninstall them. If your phone does not charge while in Safe Mode, it is some other issue.
Note: You will know your phone is in Safe Mode because a “Safe Mode” badge will show up on the screen.
To turn off Safe Mode, do the following:
  • Step 3: Touch and hold and hold the power button until phone restarts
The Phone Is Running Too Many Applications at Once
If you have too many apps running at once, this could be taking up memory and causing internal software problems that are preventing your phone from charging. Force restarting the phone will close all the apps that are running. Force restart your phone by:
  • Step 1: Connect your phone to the charger
  • Step 2: Press and hold the power and volume up buttons are the same time for 15 seconds
  • Step 3: After your phone has vibrated 3 times, release the keys. Your phone will now shut down.
  • Step 4: Press the power key to turn your phone on after waiting 30 seconds
The Software Is Not Up-To Date
If the software on your phone isn’t up to date, it could be causing internal issues that are preventing your phone from charging. To update your software, follow the steps below:
  • Step 1: Go to Settings
  • Step 2: Go to About Phone
  • Step 3: Go to Software Update
Note: If none of the solutions above are solving the issue, your USB charging port might be damaged and you might need to replace the power USB-C.
The Phone Battery Is Draining Quickly
The phone battery drains faster than expected.
If the software on your phone isn’t up to date, it could potentially be missing updates in which Sony has fixed battery performance issues. To update your software, follow the steps below:
If you have too many apps running at once, this could be taking up memory and drain the battery life. Force restarting the phone will close all the apps that are running. Force restart your phone by:
The Applications Are Consuming Too Much Power
Check to see if there are apps running that consume more power than it should. In order to see what apps are consuming the most power, follow the steps below.
  • Step 1: Find and tap Settings > Battery to view the estimated remaining battery percentage and battery time
  • Step 2: Tap Advanced for more details about battery usage
  • Step 3: Disable unused apps that consumes battery
The Brightness Is Too High
Higher brightness can cause the battery to drain faster. Try using your phone at a lower brightness.
The Charger Is Not Certified
Make sure you are using a certified USB-C charger from Sony. Other third-party chargers could alter the way the battery is charged and damage the battery.
The Battery May Be Faulty
If none of the other remedies resolve the issue, the battery may be faulty and require a replacement.
The Front Screen Has Unresponsive Pixels
There are pixels on the screen that are black.
The Phone Needs to Be Restarted
Try restarting the phone to see if the pixels return to their proper color and start responding.
The Pixels Are Stuck
Free applications can be used to test and fix stuck pixels. There are websites online or downloadable apps that use software to flash multiple colors on the area of the screen where the stuck pixels are. This method can often fix stuck or dead pixels within ten minutes.
The Pixels Are Dead
If the pixels fail to respond to attempts to unstick them or the area of the screen with the unresponsive pixels has lost touchscreen capabilities, the screen is likely faulty. To fix a faulty screen, the screen may need to be replaced.
The Phone Overheats Often
The phone is often hot to the touch.
The Processor Is Handling Too Many Operations
The use of an application while simultaneously running background applications requires a lot of processing power. This can overwork the processor causing it to overheat. Close unnecessary applications that may be drawing power.
The Use of an Incompatible Third Party Charger
Using a third party charging cable that is incompatible can result in overheating. It is always best to use the original charging cable; however, if you no longer own the original cable, find a USB-C certified by Sony.
The Ambient Temperature Is Hot
If the air surrounding the phone is warm, it can make it difficult for the phone to cool down. Move the phone into a cooler environment.
The Use of Applications or Functions That Draw a Lot of Power
Applications, like graphically intense video games or HD video, can use a lot of power causing the phone to overheat. Take breaks and allow your phone to cool down before returning to your application.
The Touchscreen Is Unresponsive
The screen does not respond when being touched.
The Screen Is Dirty or Has a Screen Protector
Wipe the screen with a clean cloth. If there is a screen protector, make sure there are no air bubbles or dirt under the screen protector.
Try turning the phone off and on to see if the screen starts responding. If turning it off and on normally does not work, the phone may need to restarted or shut down. To shut down the phone hold the power button and the lower volume button at the same time for six seconds. After this the phone will vibrate once. To restart the phone release now. To force shut down the phone continue holding until the phone vibrates three more times and turns off.
The Touchscreen Functionality Settings
The settings for the functionalities of your touchscreen may be changed. Carry out the touchscreen functionalities test for your device by following these steps:
  • Step 1: Go to Settings > Support
  • Step 2: Select the Tests tab and select a test
  • Step 3: Follow the directions for the test and discover whether the device passed the test or not
If the software on your phone isn’t up to date, it could potentially be missing updates in which Sony has fixed screen performance issues. To update your software, follow the steps below:
The Screen Is Damaged
To fix a damaged screen, the screen may need to be replaced.
Author
with
Dan Nguyen
344 Reputation
1 Guide authored
Cal Poly, Team S19-G5, White Winter 2019 Member of Cal Poly, Team S19-G5, White Winter 2019
CPSU-WHITE-W19S19G5
4 Members
60 Guides authored
4 Comments
sony xz2 premium switched off and wont respond to turning on, I have tried holding down volume and start buttons but still no response, any ideas?
bigjulesverne - Reply Share
same thing is happening to my phone right now. were you able to resolve yours?
Femi John - Reply Share
Same thing is happening to my phone it eventually does turn on, but it is happening more frequently. Concerned I might not be able to turn it on at some point.
Basil Tsiaousopoulos - Reply Share
Mine does bling only when iam trying to charge it by still not charging
diamondmjaha - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 8,592
