Sony Xperia XZ2 Battery Replacement
    1. Sony Xperia XZ2 Battery Replacement, LCD Screen: step 1, image 1 of 3 Sony Xperia XZ2 Battery Replacement, LCD Screen: step 1, image 2 of 3 Sony Xperia XZ2 Battery Replacement, LCD Screen: step 1, image 3 of 3
      • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
      • The phone gets very hot and can hurt the user handling it.
      Ask FixBot
    2. Sony Xperia XZ2 Battery Replacement: step 2, image 1 of 3 Sony Xperia XZ2 Battery Replacement: step 2, image 2 of 3 Sony Xperia XZ2 Battery Replacement: step 2, image 3 of 3
      • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
      • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
      Ask FixBot
    3. Sony Xperia XZ2 Battery Replacement: step 3, image 1 of 2 Sony Xperia XZ2 Battery Replacement: step 3, image 2 of 2
      • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
      • The screen is still attached by a connector, so do not pull the pieces apart.
      Ask FixBot
    4. Sony Xperia XZ2 Battery Replacement: step 4, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
      Ask FixBot
    5. Sony Xperia XZ2 Battery Replacement: step 5, image 1 of 1
      • Gently remove the connector by using a spudger to pop it off.
      Ask FixBot
    1. Sony Xperia XZ2 Battery Replacement, Battery: step 6, image 1 of 1
      • Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
      • Remove the one 3 mm Phillips #00 screws.
      • Remove the two 1mm Phillips #00 screws.
      • Fifteen screws should be removed in total in this step. (Not all the screws are visible in the picture.)
      Ask FixBot
    2. Sony Xperia XZ2 Battery Replacement: step 7, image 1 of 1
      • Lift the metal screen shield out of the phone.
      Ask FixBot
    3. Sony Xperia XZ2 Battery Replacement: step 8, image 1 of 3 Sony Xperia XZ2 Battery Replacement: step 8, image 2 of 3 Sony Xperia XZ2 Battery Replacement: step 8, image 3 of 3
      • Use the spudger to pry up the battery flex connector to pop the battery out.
      Ask FixBot
    4. Sony Xperia XZ2 Battery Replacement: step 9, image 1 of 1
      • Lift the battery out of the phone.
      Ask FixBot
6 other people completed this guide.
Arti Jain
261 Reputation
1 Guide authored
Cal Poly, Team S19-G5, White Winter 2019 Member of Cal Poly, Team S19-G5, White Winter 2019
CPSU-WHITE-W19S19G5
4 Members
60 Guides authored
1 Guide Comment
لقد كان العمل على هذا الهاتف مريحا جدا و جميل
Mouad Driouch - Reply Share
Past 24 Hours: 9
Past 7 Days: 75
Past 30 Days: 358
All Time: 34,070
