Optical drive won't read, or optical drive won't open
Optical drive
There can be a number of issues that can cause your optical drive to stop functioning or reading discs. First, be sure the disc is not the problem. Look for scratches and try another disc if necessary. If your drive won't open try to use a paper clip and stick it in the small hole located near the tray opening button this will eject the tray and you can put your disc in.
Replace CD drive
Because the complexity of the CD drive it is hard to manually fix it. The laser and all the small components attached to the CD drive break easily. Due to the complexity of the optical drive, it is recommended to just replace it. See Sony Vaio VGN-S260 Optical Drive Teardown for instructions on how to replace it.
Laptop shuts down without warning
You were working on that file and didn't have time to save it...
Overheating
On many laptops, the most common reason is poor cooling. Try going somewhere air-conditioned and see if that helps. Inspect the areas near the internal cooling fan to see if there is a build up of dust. This could be clogging the fan from working properly so take a quetip to clean it out. This overheating can also be caused by constant, strenuous use, so take a break from the computer for a while and see if that helps.
Laptop shuts off when I unplug it
As soon as you unplug the computer from its power source, it shuts off.
Dead battery
If your battery is dead, the computer will run fine off the power adapter, but will turn off when unplugged. A dead battery can manifest itself in many forms: It may not accept a charge (this particular symptom may also indicate a problem with the logic board), the computer may not recognize the battery, or the battery may be recognized as charged but fail to power your computer when the AC adapter is unplugged.
Sony Vaio won't turn on
Your computer will not boot.
Battery not working
One of the main reasons why your computer may not be booting is that the battery may be unuseable. Try replaceing it with a new or slightly used one. [Google battery search].
See Sony Vaio VGN-S260 Battery Teardown for instructions on how to replace it.
Bad power adapter
If your power adapter is bad, the computer will run off a battery, and it won't charge. The best way to test this is to borrow either a battery or power adapter to test. Also make sure the power cord is firmly plugged into the wall socket and the laptop. If the first socket does not work, try another one. If you have the same problem with another power adapter, your problem is most likely the logic board. Compatible power adapters can be found on the internet [Google power adapter search].
See Sony Vaio VGN-S260 Power Adapter Teardown for instructions on how to replace it.
Also See
Jeffrey Bryan
570 Reputation
11 Guides authored
Cal Poly, Team 16-4, Maness Spring 2010 Member of Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Members
132 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 21
All Time: 6,247
