Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Cannot connect to a Wi-Fi network
The device will not connect to networks and/or drops connections.
Router or device need to be restarted
Reset the router in use, and restart the device. Wait at least 5 minutes for both to reboot, then try connecting to the network again.
Device needs a soft reset
Press the “reset” button on the side of the tablet, next to the volume controls, with a small, pointed object. This will close all applications and restart the device.
Connection needs to be reconfigured
The device comes with an application called “Wi-Fi Checker” that will analyze the connection and report steps for the user to follow in order to sort out the issue.
Wi-Fi antenna needs to be replaced.
If the above steps do not solve the Wi-Fi issue then the problem may be hardware related and the Wi-Fi Antenna could need replacing. Use this guide to replace the Wi-Fi antenna.
Screen not responding to touch
Screen is not responding to touch, or is responding inaccurately.
Screen needs to be cleaned
Wipe screen with a microfiber cloth and cleaning solution if available.
Device is getting too hot
Using the device while connected to power can sometimes generate enough heat to disorient the touchscreen. If the device feels warm to the touch especially near the screen, unplug the charger and wait a few minutes. If the problem persists, see Overheating and/or unexpected shutdown.
Screen needs to be calibrated
Obtain the Touchscreen Calibration application from the Google Play Store app and use it to calibrate the touch screen. This should improve the screen’s ability to accurately detect touches.
Screen needs to be replaced
If the above steps do not resolve the issue, then the screen may need to be replaced. Heat gun is required for replacement.
Will not charge
The device does not indicate it is charging while the power adapter is connected.
Debris in the charging port
If the device does not indicate it is charging while connected to power, the connector may not be completely seated in the charging port. Inspect the device’s charging port, which is located on the bottom left side if looking at the screen, using a flashlight and/or magnifying glass. If the metal contacts appear dirty, clean them with a cotton-swab with a small amount of isopropyl alcohol. Do the same if the contacts on the cable appear dirty. If there is debris in the charging port, use a pair of needle-nose tweezers to remove it. Ensure that you dispel any electrostatic discharge you may have built up on your body prior to using metal tweezers to avoid damaging the device.
Power adapter is faulty
Inspect the power adapter cable and make sure it is free of any breaks or fraying. If fraying is present, stop using the cable and order a new one from the manufacturer. Ensure that the cable is connected to a working power outlet directly from the wall. If you have another power adapter available, use it instead. Even if the cable appears undamaged, it may still be faulty, especially if it is not a power adapter made by the original manufacturer. Continuing to use a faulty power adapter can cause internal damage to the device.
Charging connector needs to be replaced
If the above steps do not solve the issue, then the charging connector needs to be replaced. Use this guide to replace the charging connector
Unexpected shut down due to overheating.
Overheating after prolonged use
If the device suddenly shuts down and feels hot, the device is either being used for too long or is in a hot environment. Shut down the device for at least an hour, or until it feels cool to the touch. If the problem persists even after only a few minutes of use in a moderately cool environment, immediately discontinue use as there may be a problem with the battery. You can use this guide to replace it.
Overheating due to charger
It is normal for the device to feel warm while or after charging. However, if the device is uncomfortably hot, shut it down, disconnect the charger, and wait for the device to cool. If the problem persists even after only a few minutes of use in a moderately cool environment, immediately discontinue use as there may be a problem with the battery. You can use this guide to replace it.
Battery is faulty
Unusual heating may indicate that the battery needs to be replaced. If you experience excessive heat after only a few minutes of use, immediately discontinue use as there may be a problem with the battery. You can use this guide to replace it.
Will not turn on
The device does not turn on when the power button is pressed.
Battery is not charged
If the device does not turn on, ensure that the battery is charged by connecting the power adapter to the unit and a working power outlet and wait at least 20 minutes before pressing the power button again. If this does not resolve the issue, see Will not charge. If the device turns on after the battery has been charged but immediately shuts down after the power adapter is disconnected, there may be a problem with the battery. You can use this guide to replace it.
Device is frozen
If the device does not display anything on the screen but appears as if it may still be on, it may need to be reset. Connect the device to the power adapter and wait at least 20 minutes. If the device does not either turn on automatically, or turn on when the power button is pressed, press the “reset” button on the side of the tablet, next to the volume controls, with a small, pointed object. The Sony logo should appear on the screen and the device should reboot. If nothing is shown on the screen, there may be a hardware issue with the device.
Author
with
Austin Mann
287 Reputation
5 Guides authored
USF Tampa, Team 3-5, Passmore Fall 2016 Member of USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 Members
60 Guides authored
5 Comments
The device shows the Sony logo but does not boot any further.
Have tried a hard reset to factory settings witout success
Iancu - Reply Share
Tablet S SGPT113CH/S
Cannot send IR-Commands to any device and cannot make the RemotControl application learn from any remote-control
Is the IR-Interface really working ??
Aronne - Reply Share
My battery is draining and it shut down by itself
Damian Kurtz - Reply Share
My Tablet S still works but doesn’t connect to Web anymore. Though it can receive mail via Gmail client…what can be done? Play Market doesn’t connect as well :(((
Alex Stavitsky - Reply Share
My device shows Sony and does not go further is at only on graphics running.
Karthick Selvan - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 26
All Time: 4,586
