Up to 20% off select tools
Sony Tablet S Battery Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
119
All Time:
3,717
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help users replace the battery on their Sony Tablet S. This requires a Phillips #0 and #000 screw driver, as well as a spudger and some plastic opening tools.
    1. Sony Tablet S Battery Replacement, Battery: step 1, image 1 of 2 Sony Tablet S Battery Replacement, Battery: step 1, image 2 of 2
      • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
      • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
      Ask FixBot
    2. Sony Tablet S Battery Replacement: step 2, image 1 of 1
      • Remove the two 10mm Phillips #0 screws located under the grips.
      Ask FixBot
    3. Sony Tablet S Battery Replacement: step 3, image 1 of 2 Sony Tablet S Battery Replacement: step 3, image 2 of 2
      • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
      • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
      Ask FixBot
    4. Sony Tablet S Battery Replacement: step 4, image 1 of 1
      • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
      Ask FixBot
    5. Sony Tablet S Battery Replacement: step 5, image 1 of 1
      • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
      • Use caution when removing the cable, as the socket is very fragile.
      Ask FixBot
    6. Sony Tablet S Battery Replacement: step 6, image 1 of 1
      • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
      Ask FixBot
    7. Sony Tablet S Battery Replacement: step 7, image 1 of 1
      • Slide the bottom grey cover piece away from the body and remove it.
      • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
      Ask FixBot
    8. Sony Tablet S Battery Replacement: step 8, image 1 of 1
      • Remove the five 4mm Phillips #000 screws.
      • Remove the two 5mm Phillips #000 screws holding the charger in place.
      Ask FixBot
    9. Sony Tablet S Battery Replacement: step 9, image 1 of 3 Sony Tablet S Battery Replacement: step 9, image 2 of 3 Sony Tablet S Battery Replacement: step 9, image 3 of 3
      • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
      • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
      Ask FixBot
    10. Sony Tablet S Battery Replacement: step 10, image 1 of 2 Sony Tablet S Battery Replacement: step 10, image 2 of 2
      • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
      Ask FixBot
    11. Sony Tablet S Battery Replacement: step 11, image 1 of 1
      • Remove the three 5mm Phillips #0 screws securing the original battery.
      Ask FixBot
    12. Sony Tablet S Battery Replacement: step 12, image 1 of 2 Sony Tablet S Battery Replacement: step 12, image 2 of 2
      • Use the spudger to pop the battery loose and remove the battery.
      Ask FixBot
4 other people completed this guide.
Author
with
Austin Mann
287 Reputation
5 Guides authored
USF Tampa, Team 3-5, Passmore Fall 2016 Member of USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 Members
60 Guides authored
1 Guide Comment
To change polarizer sticker of the screen, is it necessary to remove battery, motherboard etc. or I can just go with removing the adhesive of the bezel? Even after removing the bezel adhesive, is it easy to replace the sticker without damaging the lcd or digitizer?
Saravanan Theckyam - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 119
All Time: 3,717
