Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
My screen is black
Your screen is not responding and remains black.
Dead Battery
If your charger input works (as described above), you could have a battery problem. You will need to remove and check the battery to see if it's dead by using a multimeter (explained in guide below), which is commonly found at a hardware store.
See Battery Check Guide
Broken LCD
If your battery and charger input are both working (as described above), that means the LCD screen is broken and will need to be replaced.
See LCD Screen Replacement Guide
My speakers aren't working
The volume is turned up and there is still no sound.
Broken Speakers
If the sound does not work, your phone's speakers may need to be replaced.
See Speaker Replacement Guide
The buttons on my keypad don't work
Your phone is turned on and the buttons do not respond.
Broken Keypad
If the keypad is unresponsive, it may need to be replaced.
See Keypad Replacement Guide
My phone case is damaged
Your phone case is scratched or cracked.
Damaged or Broken Case
If your phone's case or plastic screen cover is damaged, you will need to remove and replace the case.
See Case Replacement Guide
Emily Prescott
531 Reputation
4 Guides authored
Cal Poly, Team 14-10, Forte Winter 2011 Member of Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Members
96 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 2,424
