Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Sony DCR DVD-108 Troubleshooting
Released in 2007. Commonly called a "Sony Handicam". 40x optical zoom.
Cannot open DVD port
DVD door takes significant force to open, if at all.
The switch is physically broken
Ensure defect by toggling switch labeled "Open/Access." If door remains unresponsive attempt to open with a spudger. Do this by slipping spudger under door lip and slide along gap (in a back forth motion). If door is still unresponsive slip spudger under door lip and apply force in a prying motion. Ounce door is open check to see if door latch responds to the "Open/Access" switch. Else proceed to door latch replacement.
Cannot open lens cover
The lens cover does not move when "Lens Cover" switch is toggled.
A simple remedy is to manually force lens cover into the open (down) position or the closed (up) position by pressing one's finger to lens cover and applying force in the desired direction. If full recover of switch actuation is desired proceed to replacement of lens cover switch.
LCD screen is locked in place
The screen won't move without significant force.
The hinges may be dirty
Proceed to disengaging the LCD screen, and removing plastic cover. Inspect hinges and remove any unwanted accumulation present, unwanted build up may cause impedance of LCD screen motion.
Image is unclear and muddled
There are noticeable smudges and/or scratches when you look through the viewfinder.
The lens is dirty
First attempt to clean any sudges present on exterior plastic shield. If smudges are still visible even after thorough cleaning of shield, the lens itself may have been compromised. Open camera in order to access lens. Lightly wet cotton swab with isopropol alcohol and gently dab glass with wetted end. If image quality remains diminished then the problem is not with the lens.
The lens is scratched or cracked
You will have to replace the lenses of the camera.
Sony DCR-DVD 108 Front and Back Lens Replacement
Screen is blank or unresponsive
What I see through the viewfinder is not what I see on the screen.
The LCD connection is disconnected
The serial port connection leading from the camera to the the LCD screen may be misaligned or disturbed. Open the camera and check to see if the cable is properly attached.
The LCD screen is broken
This is easily identifiable with a a white screen with a large crack running through it. The screen will have to be replaced.
Elijah DeWolf
628 Reputation
5 Guides authored
USF Tampa, Team 7-6, Cheng Spring 2016 Member of USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Members
60 Guides authored
2 Comments
Camera turns on, but when you go to record, it records briefly, then turns off.
Robert Gilliam - Reply Share
Camera turns on, when I record, it records briefly, then shuts off.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 37
All Time: 1,476
