Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tray Won’t Open or Eject the Disc
Blu-Ray player is locked
Sometimes the Blu-ray drive is locked, and you may need to unlock it. Turn on the Blu-Ray player, and check to see if D ON or LOCKED appears on the front panel. If so, you may need to unlock the disk drive. To unlock the disk drive press and hold the eject button on the Blu-ray player until D OFF appears on the front panel, the tray will open.
Faulty Disc
In case you put a disc in and the Blu-ray drive won’t open you can solve this issue very quickly. The recommended way to resolve this is to first power off your device, then unplug the power cord. Wait about 30 seconds, and plug the power cord back in. Once the Blu-ray player is on, press and hold the EJECT button. The tray should open, with the tray still open, remove the disc and unplug the Blu-Ray player. The device will close the tray and reset.
Faulty Disc Drive
If the above solutions do not work, you may have a faulty Blu-ray drive, and may need to replace it.
Unable to Play Blu-Ray Disc Movie
The disk may be in upside-down
Open the disk tray and ensure the disk has been inserted in the correct orientation.
Disk may be dirty or scratched
Ensure that the disk is clean and/or does not have any scratches which might hinder the devices ability to read the disk.
Device may not be connected to power
Check the to ensure the device is plugged into a power outlet and is receiving power.
Faulty DVD Reader
If the problem persists, you may need to replace the DVD reader.
No picture when I use an HDMI connection
Either an incorrect or no picture at all is displayed when there is an HDMI cable connecting the Sony BDP-S7200 to the television.
The HDMI cable may be faulty
Disconnect the HDMI cable from the Sony BDP-S7200 and the other device it is connected to. Connect a different HDMI cable to both in-place of the first. If an image still does not display on the television, then the HDMI cable is not your problem.
The Input setting is incorrect
Using the Remote, press INPUT, until the display device is displayed as the HDMI Sony BDP -S7200.
The output settings are not compatible with the television
Some TVs can only accept a 1080p/60p video. Change the display output on the Sony BDP-S7200 to match one of the accepted inputs of the TV.
Won't turn on
In the instance the Blu-ray player won’t turn on, it may be a number of problems. It could be a faulty electrical outlet, the HDMI cord could be faulty, or you may need to replace the power supply board [Link].
Faulty Electrical Outlet
Make sure the Blu-ray player is plugged into a working electrical outlet, or try plugging the Blu-ray player into another outlet. If you are using the power button on the remote control, try pressing the power button on the Blu-ray player.
Faulty HDMI Cord
In some cases, a Blu-Ray player may not turn on due to a faulty HDMI cord. If the Blu-Ray player is connected to the TV via a HDMI cable, unplug the HDMI cable and turn on the device. If the device turns on, turn off the [Control for HDMI ] from the [System Setting Menu] . You may try replacing the HDMI cable if the issue persists.
Faulty Power Supply Board
If the above steps don’t work, you may need to replace the power supply board.
Lose Internet Connection
This type of error occurs if your device will not connect to the internet in the first place or if the connection is not stable. If other devices cannot connect to the internet as well, it is most likely an issue with your router, not the Blu-ray player.
The device cannot connect to wifi
  1. Using the remote, enter the settings menu for the player.
  2. Select the [Easy Initial Settings] option
  3. Select the [Easy Network Settings] option
  4. If this does not work it is possible the Blue-ray player is too far from the router. Try moving the Blu-ray player closer to the router.
Author
with
Erik Preston
415 Reputation
3 Guides authored
1 Comment
It seems that my Sony BDP-S7200 is overheating or something. After while the video & audio go black for a second, then continues to work again. It does this often once it starts to do so. Is there a way to install a fan? What is the correct solution? Thanks!
Luke Muston - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 38
All Time: 2,397
