Sony BDP-s7200 Disk Drive Replacement
    1. Sony BDP-s7200 Disk Drive Replacement, Back Cover: step 1, image 1 of 1
      • Remove the disk tray cover from the device.
      Ask FixBot
    2. Sony BDP-s7200 Disk Drive Replacement: step 2, image 1 of 2 Sony BDP-s7200 Disk Drive Replacement: step 2, image 2 of 2
      • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
      • Remove the metal cover.
      Ask FixBot
    3. Sony BDP-s7200 Disk Drive Replacement: step 3, image 1 of 2 Sony BDP-s7200 Disk Drive Replacement: step 3, image 2 of 2
      • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
      Ask FixBot
    4. Sony BDP-s7200 Disk Drive Replacement: step 4, image 1 of 1
      • Pull off the back panel and remove it from the device.
      Ask FixBot
    1. Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: step 5, image 1 of 3 Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: step 5, image 2 of 3 Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: step 5, image 3 of 3
      • Using the plastic opening tool, open one of the tabs on the bottom of the device.
      • While keeping the tab open, insert a opening pick in between the opening tool and tab.
      • Repeat this for the 3 other tabs.
      Ask FixBot
    2. Sony BDP-s7200 Disk Drive Replacement: step 6, image 1 of 2 Sony BDP-s7200 Disk Drive Replacement: step 6, image 2 of 2
      • Place your hands on the two black circles on the bottom of the device.
      • Pull on the black circles to remove the device from its front panel cover.
      Ask FixBot
    3. Sony BDP-s7200 Disk Drive Replacement: step 7, image 1 of 3 Sony BDP-s7200 Disk Drive Replacement: step 7, image 2 of 3 Sony BDP-s7200 Disk Drive Replacement: step 7, image 3 of 3
      • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
      • Using the same screwdriver, remove the three 9mm screws from the back of the device.
      • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
      Ask FixBot
    4. Sony BDP-s7200 Disk Drive Replacement: step 8, image 1 of 2 Sony BDP-s7200 Disk Drive Replacement: step 8, image 2 of 2
      • Remove the small metal clip on the front of the device.
      • Remove the metal cover on the top of the device.
      Ask FixBot
    1. Sony BDP-s7200 Disk Drive Replacement, Disk Drive: step 9, image 1 of 2 Sony BDP-s7200 Disk Drive Replacement, Disk Drive: step 9, image 2 of 2
      • Using the Phillips #2 Screwdriver, unscrew the four 9mm screws from disk drive.
      • Disconnect the 3 ribbon cables connecting the disk drive to the motherboard
      • Pull the disk drive from the device to remove it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,176
