CLASSIC2 Won't Turn On
When trying to capture charge or charge another electronic, it won't turn on .
Power Button Was Not Pushed
Press the power button on the device. Make sure that the LED light flashes green when you press the button to ensure the CLASSIC2 has charge.
Battery is Not Charged
If your battery is dead you need to charge it using solar energy or connect it via micro USB to wall socket or a device containing USB port. When charging the power button will shine a red light.
Solar Panels are Not Positioned Correctly
If you are trying to charge it using solar energy, make sure it is in proper position facing the sun. Change the angle of the CLASSIC2 based on the sun's location. If the device is charging, the power button will shine red.
Battery Needs to be Changed
If the CLASSIC2 still doesn't turn on considering the previous solutions, a battery replacement may be necessary. The following link will take you to a replacement guide for a battery change. Solio CLASSIC2 Battery Replacement
Electric Wire Within the Device is Broken
If an electrical wire is damaged, the energy collected by the solar panels won't be stored within the battery. To replace a damage wire, follow the provided link to the wire replacement guide. Solio CLASSIC2 Electric Wire Replacement
The CLASSIC2 Won't Charge Other Devices
Battery is good to go, but devices are not charging.
Power Button was Not Pushed
Press the LED button to see if the green light is flashing when charging the device. The power button is located on the back side of the CLASSIC2.
The USB Cords are Not Connected Correctly
The USB needs to be connected on both devices. The USB connects to the CLASSIC2 and the micro USB needs to connect to the micro USB port of the device needing charge. Make sure the USB is not hanging loosely out of either device.
USB Port is Damaged
It is possible for the USB port to be damaged. If small particles like dirt or gravel get into the port, it can cause for the USB to not be connected inside the port correctly. Debris also cab cause permanent damage in the port. If this happens, the USB port needs to be replaced. The following link will take you to a replacement guide for the USB port. Solio CLASSIC2 USB Port Replacement
LED Light is Not Shining or Flashing
The LED is not shining red when charging and flashing green when charging other devices.
Check All the Connections
Double check to make sure the device is properly set up with all the connections in the correct place. Also check the positioning of the device when charging it using solar energy.
LED Needs to be Replaced
Your device may need to have the LED light replaced. A replacement guide is available on the following link. Solio CLASSIC2 LED Light Replacement
Charging Takes Longer Than Usual
Why is it taking so long to charge?
Solar Panels are Not Correctly Positioned
When using the solar panels, make sure to angle the CLASSIC2 towards the sun for maximum charge. The sun changes position throughout the day so adjust the device according so where the sun is.
Device is Not Fully Plugged into Wall Socket
When using the micro USB, make sure that the wall socket is locked into place before charging the Solio CLASSIC2. A loose socket may result in inconsistent charging. Also make sure the charging cable is fully plugged into the wall socket.
Author
with
Johnny Tran
320 Reputation
3 Guides authored
Cal Poly, Team 4-28, Amido Fall 2013 Member of Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Members
84 Guides authored
1 Comment
I have a Solio2 and I am having issues with it charging. I have tried both multiple USB cords and solar charging. in all cases the red light does come on but it never charges. I really like this unit and hope there is an easy remedy.
thank you Larry
Larry Davis - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,111
