Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Flashing Network Light on the Front of Slingbox
The network light on your Slingbox is blinking or not on at all.
Slingbox is Not Connecting to the Network
Restart the Slingbox by pressing the Reset button located on the back of the Slingbox or by unplugging the Slingbox and plugging it back in. If restarting doesn't solve this issue, check all of the connections to the Slingbox. Make sure the cables connecting to the Slingbox are in the corresponding ports and try to eliminate any unnecessary connections.
Network is Down
If you have already checked your internet connection, you may want to check your network. If you are not connected to ethernet or wireless internet, you will not have a network connection. It might also be a good idea, if using wireless internet, to reboot your home router. You can reboot your home router simply by unplugging it and then plugging it back in.
Slingbox Video is Freezing
Your Slingbox won’t stream at all or will only stream for a few minutes.
Network Connection Issues
The network connection could be failing. Restart the Slingbox by pressing the Reset button located on the back of the Slingbox and check that all the cables are properly attached to the Slingbox.
If the issue persists and you are using wireless internet you may want to reboot your home router. You can reboot your home router simply by unplugging it and then plugging it back in or pressing the reset button if it has one.
Faulty Capacitors
If you have gone through the previous steps for network connection issues, the issue might be rooted within the motherboard. For instructions on how to diagnose and replace the motherboard, check out ourMotherboard Replacement Guide.
Slingbox Does Not Have Audio
Your Slingbox does not have any sound when operating.
Faulty Ports
If you are not hearing audio from your Slingbox it is possible there might be a cable-to-port connection problem. Make sure you have all of the correct cables connected to the corresponding ports. If this has been checked, your Slingbox may have bad ports.
Author
with
Taylor Espich
13 Reputation
0 Guides authored
IUPUI, Team 1-1, Renguette SU 2016 Member of IUPUI, Team 1-1, Renguette SU 2016
IUPUI-RENGUETTE-SU16S1G1
3 Members
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 1,705
